Trex72 Posted May 28, 2010 Report Share Posted May 28, 2010 need to see so pics and or some advice on how to make a dual SU carb linkage on a l20b in a 71 pl510 ! ty . Quote Link to comment
skunk Posted May 28, 2010 Report Share Posted May 28, 2010 my camra is down right now but i got SUs on my l20 check out my thread and see if that helps http://community.ratsun.net/topic/21051-skunks-510/ Quote Link to comment
zerow Posted May 28, 2010 Report Share Posted May 28, 2010 From my Air Filter Build Thread: Hopefully this helps. If you need another pic or different angle, let me know... Quote Link to comment
Trex72 Posted May 28, 2010 Author Report Share Posted May 28, 2010 your carbs look at little different yhan the su's i have . trying to find my cam any more pics are always appreciated. Quote Link to comment
Trex72 Posted May 28, 2010 Author Report Share Posted May 28, 2010 your carbs look at little different than the su's i have . trying to find my cam any more pics are always appreciated. Quote Link to comment
Logical1 Posted May 28, 2010 Report Share Posted May 28, 2010 Check out this post: Su's Linkage I have my dual Su's on a L18 but dual Su's are dual Su's.... I have slightly modded the spindle pull since then But not much... Hit me up if you have any questions :) Quote Link to comment
MikeRL411 Posted May 31, 2010 Report Share Posted May 31, 2010 your carbs look at little different than the su's i have . trying to find my cam any more pics are always appreciated. SU by Hitachi come in 2 basic varieties. Round Top and Flat Top Round top installations have 2 variations. Fuel bowls both on the left viewed from the driver's fender, and front carb bowl on the left, rear on the right. On ocasion some flip the second configuration so that both bowls are in the center [probably for firewall or clutch mastercylinder clearance]. Quote Link to comment
skunk Posted May 31, 2010 Report Share Posted May 31, 2010 yeah, the l20 is taller and my throttle rod was being bent up in a way that made it pop off real easy, tryed to fix it a broke my throttle rod. Quote Link to comment
