playsnmud Posted July 24, 2007 Report Share Posted July 24, 2007 I have had this z22 and 5speed for about 4 years now, and was think about putting it in the 510 so I would have a little more power and a 5spd. but all I have is the motor (without intake manifold) and trany, would a 200sx wiring,ecu,etc. work on this motor? any good articles? I found a 200sx and he said it has a 2.0L 8plug motor in so that would have to be a z20 right? now can't I use the rear disk stuff and diff? HELP ME????? Quote Link to comment
datsunaholic Posted July 24, 2007 Report Share Posted July 24, 2007 Kinda depends on what you have. Quote Link to comment
playsnmud Posted July 24, 2007 Author Report Share Posted July 24, 2007 when you say what do I have, what do you mean? Quote Link to comment
datsunaholic Posted July 24, 2007 Report Share Posted July 24, 2007 What year of 510 and whether it's a Wagon or a Sedan (for the rear discs). 200SXs have live axles, '68-73 510 sedans do not. Quote Link to comment
kiznook Posted July 24, 2007 Report Share Posted July 24, 2007 you could just give it to me! that would solve your problems Quote Link to comment
playsnmud Posted July 24, 2007 Author Report Share Posted July 24, 2007 funny funny kiznook, would that be nice kill 2 birds with 1 stone. I got a 72 4dr 510. Correct me but don't people use the disc and caliper off the 200sx's to do the disc brake onto the 510's, Quote Link to comment
kiznook Posted July 24, 2007 Report Share Posted July 24, 2007 you can use the front strut and bakes, and I'm 90% sure you can use the rear disks, but its a bit of work. What year is the 200sx? Quote Link to comment
playsnmud Posted July 24, 2007 Author Report Share Posted July 24, 2007 its an 82. i don't need the front struts/brakes cause i already have 280zx up front. my concern is that icehouse was saying something about the s12 wiring is hard to hook up into dimes than sr/ka. Quote Link to comment
kiznook Posted July 24, 2007 Report Share Posted July 24, 2007 as I understand it it's far easier than ka/sr. only a few wires that need tobe spliced into the car, the rest is self contained. but I woudn't question Icehouse, he has a lot more experience wiring these things! Quote Link to comment
playsnmud Posted July 24, 2007 Author Report Share Posted July 24, 2007 icehouse knows his $hit thats a fact. can't be that bad to do, I've done much more complicated ecu wiring on my turboed integra. going to do it. Quote Link to comment
Duke Posted July 24, 2007 Report Share Posted July 24, 2007 Here's what you do: Get a l-series U67 head, take the head off the z22, modify the block to fit the U67 head, and make yourself a LZ22 hybrid. The L head flows WAY better than the Z head, and with the long stroke of the Z22 you get a really touquey engine...there I solved your problem for you. Quote Link to comment
DISLEXICDIME Posted July 24, 2007 Report Share Posted July 24, 2007 i thought it was only eight wires to splice the efi on a z engine in to a 510 harnis Quote Link to comment
kiznook Posted July 24, 2007 Report Share Posted July 24, 2007 i thought it was only eight wires to splice the efi on a z engine in to a 510 harnis yeah, 7 or 8, something like that LZ hybrid wouldn't be a bad way to go either....I'm pretty sure I'm gonna build a 2.1 longrod. I think it would be fun. I want to use 89mm pistons though. Hmm, after some more thinking, I'll post a seperate thread. stay tuned! Quote Link to comment
playsnmud Posted July 24, 2007 Author Report Share Posted July 24, 2007 huh LZ22 sound decent, now just how to go about doing it is the question. the wiring is around 7 wire according to this article i read. ok now i am running in circles Quote Link to comment
kiznook Posted July 24, 2007 Report Share Posted July 24, 2007 http://www.the510realm.com/PNphpBB2-viewtopic-t-2887.html Quote Link to comment
playsnmud Posted July 24, 2007 Author Report Share Posted July 24, 2007 thanks kiznook now I got a headache from reading all that information, thats alot of monkeying around to make a LZ22. I think I'm going to just put the z22 in and skip the L part. if I end up wanting more power out of the z22 I would just do a sr or ka. And i thought hondas were hard....:confused: Quote Link to comment
kiznook Posted July 24, 2007 Report Share Posted July 24, 2007 HERES A QUESTION: where do you get a 87mm L head gasket? Quote Link to comment
playsnmud Posted July 24, 2007 Author Report Share Posted July 24, 2007 your goign to use a z headgasket cause the L series biggest bore is 86 same as a z but your going to want to use a 89 mm z24 gasket, am i close to right???? and a U67 head is for of the L20b you want to use the L16 oil pan and sump make a different location for the dipstick Quote Link to comment
kiznook Posted July 24, 2007 Report Share Posted July 24, 2007 not without modification to the gasket, the timing cover shape is different. on the LZ20, It's simple, you just use the l20 gasket. Maybe I just need to put an open chamber head on my LZ and actually lower my compression. Frankly the dame thing needs rebuilt completely! Quote Link to comment
playsnmud Posted July 24, 2007 Author Report Share Posted July 24, 2007 but thats on the z20 it said on there that the z22 has 87mm and the z24 has 89mm. i can't use the L20 gasket on a z22 right??? But either way it something I don't feel like doing cause the i would have to gather more parts which = more money sounds like a revvy motor though Quote Link to comment
hang_510 Posted July 24, 2007 Report Share Posted July 24, 2007 the 200sx ECU, and acc requires 6 or 7 wires to hook up, should be easy. datzenmike has all those answers :cool: staying all Z22 just use a Z22 HG, an LZ requires a few holes in the HG. nismo 88.5mm HG would also work, they may still be avail... i sold my Z22 top end stuff already i had a headache from reading all the info and changed my mine too many times. once i spent some $$$, i stoppped...just a little bit :rolleyes: Quote Link to comment
Duke Posted July 25, 2007 Report Share Posted July 25, 2007 For big bore l-series, check out this super JDM tyte stuff...haha, actually, there is some really nice L-series stuff on this site, a little pricey though. http://www.zccjdm.com/ Quote Link to comment
playsnmud Posted July 25, 2007 Author Report Share Posted July 25, 2007 whats the advantage of a LZ than doing a ka or sr? Quote Link to comment
