MIG Welder question
I just recently purchased a used Mig from craigslist that I will use for bodywork. I tested it last weekend and here's the situation. The welder has 4 heat range settings, the first 2 work fine and 3 & 4 nothing. I opened it up to check for anything obvious, but couldnt find anything. The switch looks fine. Is there some sort of fuse that works for the 2 higher settings?
Oh, and the guy I bought it from said it all worked fine before he listed for sale:blink:
Its a Powermate Professional Tote Mig 117-027
  • Replies 4
thats just it, i would call the man. and check. they would know whats going on or point you in the right direction.
BTW, if its a non -gas i highly suggest you dont try it on sheet metal..it'll just end up warping the piss out of your body.
Check the man if its a newer one then there still might be a warrenty just dont tell them you bought it used...... and if its flux you can still use it for body work but you have to work slow and with a spray bottle it cool it down iv done a lot of body work with mine and its came out fine just a little more clean up
