Datsun L series auto trans pix
  • Please log in to reply
107 replies to this topic
#101 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 72,217 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 02 April 2018 - 09:11 PM
I looked at this and while it probably will bolt on I saved the bell from the L4N71B because I knew it worked. The L471B bell bolts to the overdrive unit and not the tranny case itself. I'll try to get around to puilling it out of storage.
Posted Image
#102 noramost
noramost
    Advanced Member
  • Members
  • PipPipPip
  • 88 posts
  • Cars:510, 240Z, Pathfinder, D21
Posted 11 April 2018 - 11:24 AM
Great chat- I don’t know if this is useful information but for the 71-WPL510 I built in the 80’s I installed a Z24. I had to weld a 1.5” tube through the pan for the drag-link to go through and I heard the best JATCO at the time was in the ZX-Turbo so I use one. I don’t remember why but I sent the converters to Hugh’s Converters and they cut the converters at the weld on a lathe and used the Z24 on the engine side and the L28 on the trans side and welded up the seam. I also had them give me a 3 grand stall speed which is perfect for a long stroke but overheats in the VG’s
Cub Scout Promise
I promise to do my best
To do my duty to God and my country,
To help other people, and
To obey the Law of the Pack
#103 datzenmike
datzenmike
    KING RAT
  • 72,217 posts
Posted 11 April 2018 - 11:31 AM
The ZX turbo auto uses more plates and clutches, a modified modulator valve, higher line pressure and a higher stall speed converter than the 4 cylinder ones.
Posted Image
#104 noramost
noramost
    Advanced Member
  • Members
  • PipPipPip
  • 88 posts
Posted 11 April 2018 - 12:22 PM
We used to modify modulators with our side-cutters, we would cut an 1/8" off the pin so they would shift later but we usually just move the stick from 1-2-3 at 5 grand
Cub Scout Promise
#105 datzenmike
datzenmike
    KING RAT
  • 72,217 posts
Posted 11 April 2018 - 12:50 PM
Maybe you can answer this question. Did the zx turbo automatic have a larger driveshaft spline? I think it did.
Posted Image
#106 noramost
noramost
    Advanced Member
  • Members
  • PipPipPip
  • 88 posts
Posted 11 April 2018 - 01:17 PM
I had only 2 Datsun yokes I cut off drive lines to slide on the trans so they wouldn't leak when I pull the transmissions and the big 1 worked on this trans the small 1 was for B210's and I cut the splines off the out-put shafts big and little to align clutches and they slid rite in the yokes so I kept them as a set and they worked on everything, standard and auto that's one of the reasons we smiled working on Datsun/Nissan
Cub Scout Promise
#107 datzenmike
datzenmike
    KING RAT
  • 72,217 posts
Posted 11 April 2018 - 01:40 PM
I had a zx auto from a turbo car and can't remember for sure.
Posted Image
#108 noramost
noramost
    Advanced Member
  • Members
  • PipPipPip
  • 88 posts
Posted 12 April 2018 - 06:03 AM
I was remembering last night that the shop that built my turbo trans for me used a non-turbo main shaft and put the bigger drums on it to hold more clutches and steels and built me an extra strong jatco. I think they used the smaller main shaft so a normal size yoke would fit which was easier to find so I would like to change my answer to a definite maybe, I don’t think I ever pulled a turbo jatco in my 50 year carrier to know for sure. Jatco’s never broke so we didn’t ever had to mess with them, they went into this fail safe mode when 1 ½ qt low on ATF and went into neutral when all the others liked to burn themselves up when low on fluid.
Cub Scout Promise
