DatDoug Posted December 7, 2008 Report Share Posted December 7, 2008 Where do I get one of these? I want to lower my dime and do some suspension work. Quote Link to comment
rat tail dragger Posted December 7, 2008 Report Share Posted December 7, 2008 r u gunna run different wheels on the 510 thing would look sweet dumped Quote Link to comment
bonvo Posted December 7, 2008 Report Share Posted December 7, 2008 im also interested in this i searched in the suspention forum and got nothing i know ive seen it somewhere i just dont know where Quote Link to comment
slodat Posted December 7, 2008 Report Share Posted December 7, 2008 (edited) Where do I get one of these? I want to lower my dime and do some suspension work. Kelvin Dietz makes a very nice adjustable crossmember. You can buy it here. Detailed instructions on building one of these is covered in a past Dime Quarterly issue. DatSport also makes a very cool adjustable rear crossmember. Byron over at the 510 realm makes a VERY cool set of rear camber/toe adjusters. They allow you to properly align the rear on lowered 510's. I plan to run this setup on my 510. Edited December 7, 2008 by slodat Quote Link to comment
heirfaus Posted December 7, 2008 Report Share Posted December 7, 2008 Byron over at the 510 realm makes a VERY cool set of rear camber/toe adjusters. They allow you to properly align the rear on lowered 510's. I plan to run this setup on my 510. +1 hell those brackets are so cool I'll give it a +1,000,000 Quote Link to comment
freaky510 Posted December 7, 2008 Report Share Posted December 7, 2008 i tought kelvin stopped makeing stuff.At least Thats what he said at canby 08 I know of a guy whos having some tabs made i will have to give him a call to see if their done and get a price Quote Link to comment
sssr20det510 Posted December 7, 2008 Report Share Posted December 7, 2008 I like the datsport one Quote Link to comment
slodat Posted December 7, 2008 Report Share Posted December 7, 2008 I like the datsport one Baz makes a nice crossmember. But the cost for one is nearly $1k with shipping and core charge. His doesn't accomplish anything that Byron's doesn't as well.. Quote Link to comment
Gensaiken Posted December 7, 2008 Report Share Posted December 7, 2008 kelvin still makes them, its just that he gets kind of low on cores. I haven't asked him about those crossmembers in a while. I've done the slotted crossmember. The trick is to get a grinding bit that you can notch out the hole enough to allow the bolt to move far enough backwards or forwards. Then basicly once you've grinded out enough (Need to do a lot of grinding), you take it to an alignment shop and give them your desired toe and camber and they adjust it. Then quickly go to a muffler shop or weld your self the washers attached to the bolt in their spot to keep the alignment. Do not weld the bolt but the washers on each side of it. My camber and toe are perfect and because it is welded it won't be moving any time soon. So with an adjustable one you can get a pretty wide range but how often are you really going to be adjusting it? You can get the same results just widening your current holes on your cross member and then welding the washers in place when you are done. Fairly simple. If i've done it than anyone can do it. Quote Link to comment
qwik510 Posted December 7, 2008 Report Share Posted December 7, 2008 Here is a great article written by Kelvin that explains how to properly slot the rear crossmember. http://dimequarterly.tierranet.com/articles/tech_crossmember_slotting.html Thanks to the Dime Quarterly for posting this info. Quote Link to comment
Gensaiken Posted December 7, 2008 Report Share Posted December 7, 2008 Here is a great article written by Kelvin that explains how to properly slot the rear crossmember. http://dimequarterly.tierranet.com/articles/tech_crossmember_slotting.html Thanks to the Dime Quarterly for posting this info. good idea posting that. I forgot to metion grinding down the washers. That is exactly how I did mine as guided by Kelvin Dietz. :D Quote Link to comment
DISLEXICDIME Posted December 8, 2008 Report Share Posted December 8, 2008 nelson makes them to http://www.alteredmotives.com/ Quote Link to comment
Baz Posted April 6, 2009 Report Share Posted April 6, 2009 Just in case you are not up to date. We have DIY kits for our ARCs. Not that difficult to do, the clean up is the worst part. Due to the current exchange rate we can supply these to US customers at US$ 220 delivered via Express post. or US$200 by snail mail. http://www.datsport.com/ARC_DIY_kit_Fitting_instructions.html the OZ dollar is on the way up again so get in quick. Quote Link to comment
inline4 Posted April 6, 2009 Report Share Posted April 6, 2009 Just in case you are not up to date.We have DIY kits for our ARCs. Not that difficult to do, the clean up is the worst part. Due to the current exchange rate we can supply these to US customers at US$ 220 delivered via Express post. or US$200 by snail mail. http://www.datsport.com/ARC_DIY_kit_Fitting_instructions.html the OZ dollar is on the way up again so get in quick. what would be the difference between your kit, byrons and a slotted x member? Quote Link to comment
Baz Posted April 6, 2009 Report Share Posted April 6, 2009 Slotted xmembers do not have the adjustment range & slip unless welded. Byrons & our are fully adjustable. our balances both ends, easy to adjust on an aligner as it does not require levering into position. more here. http://www.datsport.com/Adjustable_rear_cross_member.html Quote Link to comment
Guest jaimesix Posted April 6, 2009 Report Share Posted April 6, 2009 (edited) Slotted xmembers do not have the adjustment range & slip unless welded.Byrons & our are fully adjustable. our balances both ends, easy to adjust on an aligner as it does not require levering into position. more here. http://www.datsport.com/Adjustable_rear_cross_member.html I read "610 version available" . Is that current? I know the cross member in 510s and 610s are slightly different. The mounting eye of the 510 X-member is offset to the center. The 610 X-member is offset about one inch forward. The trailing arms are slightly different too, but I think the difference has no bearing. Mad Dat has sloted cross members too, for 1600 ( 510 ) and 180B ( 610 ). http://www.maddat.com.au/180b.php http://www.maddat.com.au/1600.php Jaime._______________________________________________________ Edited April 6, 2009 by jaimesix Quote Link to comment
freekwonder Posted April 6, 2009 Report Share Posted April 6, 2009 I wish these diy kits were out a year and a half ago. My friend and I did the other cross member mod in the the Quarterly. Not the slotted, but the one where you build the new mounts. Quote Link to comment
Baz Posted April 6, 2009 Report Share Posted April 6, 2009 The 510 kit is the same for the 610. The start position is 40mm for the 610. Note the maddat xmember uses cams to adjust, the same as our first version which we upgraded immediatly we found that when using an aligner that rotating the cams lifted or dropped the car. This upset the aligner & made adjustment difficult and time consuming. The cams also give full adjustment with 180 degree rotation of the cam. Not fine enough for real world application & would not allow adjustments at the track. The advantage of our type of adjustment is that fine adjustments can be made easily on the aligner. At the track adjustments can be made to fine tune the car for the conditions. This can be done without an aligner by small increments, as 0.5 turns on the adjusters can alter the handing till it is where you want it. By noting the turns & positions of the adjusters from your base point different settings can be used for different tyre & track conditions. Quote Link to comment
Guest jaimesix Posted April 7, 2009 Report Share Posted April 7, 2009 This is a 610 and a 510 cross member units side by side. Note the offsets. 610 is offset forward. 510 is offset at centre. Jaime._______________________________________________________ Quote Link to comment
banzai510(hainz) Posted April 7, 2009 Report Share Posted April 7, 2009 Is the passenger side, half shaft normal angle? Quote Link to comment
KlassicMotion Posted February 6, 2014 Report Share Posted February 6, 2014 I like the datsport one Any more thoughts the subject? Do you still prefer it? Quote Link to comment
edekalil Posted February 7, 2014 Report Share Posted February 7, 2014 If I remember I did mine the old fashion way, but it's been sitting since I took the car apart way back. I'm trying to find every thing so when work shucks me I can get it all back together one day. Quote Link to comment
