Transmission installation ??
  • Please log in to reply
26 replies to this topic
#21 Roadster-ka
Roadster-ka
    Advanced Member
  • Members
  • PipPipPip
  • 136 posts
  • Cars:71 510 wagon
Posted 12 May 2018 - 03:15 PM
On every 510 I've ever done, the exhaust keeps the engine from tilting. You must raise the front of the engine to tilt the back down. This allows the trans to clear the metal hydraulic fittings and body itself.
#22 flatcat19
flatcat19
    Back in Black
  • Senior Member
  • 20,663 posts
  • Cars:Smaller. Better. Slower. Lower.
Posted 12 May 2018 - 03:53 PM
Did you use a torque wrench to evenly install the pressure plate?
Did you over tighten the pressure plate?
Is this your first rodeo?
You can't hang if your nuts haven't dropped...it's physics
#23 Rasp933
Rasp933
    Advanced Member
  • Members
  • PipPipPip
  • 262 posts
  • Cars:70 datsun 510,74 celica,88 prelude,00 tacoma ,02 corolla
Posted 12 May 2018 - 08:38 PM
So finally I got it in .with a new clutch kit and a lot of banging/denting the firewall area
#24 Rasp933
Rasp933
    Advanced Member
  • Members
  • PipPipPip
  • 262 posts
Posted 12 May 2018 - 08:39 PM
#25 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,170 posts
  • Cars:http://www.4wdandsportutility.com/features/rover/0611_4wd_1957_range_rover/viewall.html
Posted 14 May 2018 - 08:24 AM
You banged up a 510 firewall to get the trans in?
Patience, my friend...
#26 68Datsun510
68Datsun510
    Member
  • Senior Member
  • PipPipPipPip
  • 1,383 posts
  • Cars:69 Datsun 510 4 door, 2002 Xterra 4x4
Posted 16 May 2018 - 02:07 AM
Hammers are NOT in the tool list for a clutch job. I just pulled a complete L19/trans without a single dent, patience! As well as being analytical of snags and hangups will get you through. Not brute force...
Check out Sacramento Datsun Owners on FACEBOOK - RATSUN Friendly! ^_^
_______________________
Cody Mould
1969 Datsun 510 4 Door Build Thread
2002 Xterra 4x4
Cameron Park, CA
#27 Dolomite
Dolomite
  • Senior Member
  • PipPipPipPip
  • 1,742 posts
  • Cars:1971 4 door 510, 2007 Crown Vic cvpi,1990 Supra turbo, 1970 MGB mutt job turbo
Posted 16 May 2018 - 08:36 AM
I’m guessing my post about using long bolts with heads cut off to guide the trans in were unread/unheeded.
Chrome door handles are under rated.
Link to my build thread
http://community.rat...er-project-510/
