Rasp933 Posted May 3, 2018 Report Share Posted May 3, 2018 Hi. Was thinking if the rear shocks for 280zx will fit 510 rear suspension?? Thanks Quote Link to comment
banzai510(hainz) Posted May 3, 2018 Report Share Posted May 3, 2018 What? rear of 280zx is a strut like the fronts I believe why not order rearshocks for a 510? I use the old Koni adjustable type.its more than enuff but its rebound controlled. Mine is a daily driver not a race car and its stiff enuff Tokico if still aval. gas shocks. Some ay the Camero ones fit but forgot which years 1 Quote Link to comment
Rasp933 Posted May 3, 2018 Author Report Share Posted May 3, 2018 I mean can I use rear 280 shocks in my 510 Quote Link to comment
Rasp933 Posted May 3, 2018 Author Report Share Posted May 3, 2018 I think ur rite. Quote Link to comment
DHale_510 Posted May 4, 2018 Report Share Posted May 4, 2018 The 280ZX rear shocks also hold the springs. They have much larger and stronger mounts than a 510, and they are longer. I guess it really depends on how much fabrication you want to do, but they are not a simple fit. Dennis Quote Link to comment
Dolomite Posted May 4, 2018 Report Share Posted May 4, 2018 ZX uses struts, just make up some diy coilovers and be done with it. Search ratsun for the diy qa1 coilovers, cheapest way afik. Quote Link to comment
