ChrisGoHard Posted May 2, 2018 Report Share Posted May 2, 2018 A local junkyard has a 240z. I was wondering if the front struts are the same as the 280zx struts as that's what everyone seems to recommend using to upgrade the front suspension. Quote Link to comment
datzenmike Posted May 2, 2018 Report Share Posted May 2, 2018 I think you can make them work but the 280zx are the ones you want. The spindle angle on the earlier ones may be different, Anyone? I have Maxima struts in my 710 and they are within a hair of being the same as the 280zx struts, massive caliper and vented rotor. Quote Link to comment
ChrisGoHard Posted May 7, 2018 Author Report Share Posted May 7, 2018 Ok I found a guy parting out a 280z. Not a 280zx. Is there any difference between them as far as strut assemblies? Quote Link to comment
datsunfreak Posted May 8, 2018 Report Share Posted May 8, 2018 Ok I found a guy parting out a 280z. Not a 280zx. Is there any difference between them as far as strut assemblies? You only want 280ZX. Nothing else. 240Z/280Z spindla angle is wrong, bolt pattern is wrong, everything is wrong. Quote Link to comment
datzenmike Posted May 8, 2018 Report Share Posted May 8, 2018 You can lower conservatively on your stock struts if you want. The 210 also has the larger wheel bearings just like the 280zx ones. The difference is really the strut length (which is shorter) and the massive caliper and vented rotor brake up grade you get with the zx struts. Quote Link to comment
ChrisGoHard Posted May 8, 2018 Author Report Share Posted May 8, 2018 Ok guys thank you for your help. Quote Link to comment
scooter Posted May 11, 2018 Report Share Posted May 11, 2018 If you cant find zx, s12 works but you have to monkey with the receiver ring groove or use rca's that account for this. Quote Link to comment
