Oneeye Posted April 19, 2018 Report Share Posted April 19, 2018 im currently doing the sr20 swap and im on flipping the centerlink cannot find the tapping tool size for the centerlink flip do anyone know the tool if so let me know would greatly appreciate it thx. and ill do my best to document the build. Quote Link to comment
Lozer Posted April 19, 2018 Report Share Posted April 19, 2018 which car? If it's a 510 you don't need to flip. Grind a little off the bottom and loosen your steering box and idler arm to move them forward a bit. Quote Link to comment
Oneeye Posted April 22, 2018 Author Report Share Posted April 22, 2018 its a 620 Quote Link to comment
]2eDeYe Posted April 22, 2018 Report Share Posted April 22, 2018 You can use these inserts. https://teraflex.com/shop_items/tj-driver-side-high-steer-kit-stock-tapered-insert-sleeve http://community.ratsun.net/topic/72201-important-information-about-tapered-inserts/ Quote Link to comment
]2eDeYe Posted April 22, 2018 Report Share Posted April 22, 2018 That or weld up the hole re-drill and re-taper with a tie rod reamer. If I remember correctly they have a 7 deg taper. Quote Link to comment
Oneeye Posted April 22, 2018 Author Report Share Posted April 22, 2018 ok thanks fellas 1 Quote Link to comment
