ByersJuarez Posted April 14, 2018 Report Share Posted April 14, 2018 Hey Datson/Nissan Owners, Any help identifying this wiring cluster would be much appreciatedI am having an issue finding a wring diagram that is pertinent to the information I need. I recently fixed a leak near the heater core, that started under the cowl grill, and noticed that there are a few loose harnesses/connectors under the glove box near the heater core. I will be glad to post pictures and offer any information to help the situation Thanks & regards, Ethan 1 Quote Link to comment
datzenmike Posted April 14, 2018 Report Share Posted April 14, 2018 The only thing under the glove box is the heater fan assembly. The heater core is over under the middle of the dash in front of the console and connected to the fan by a large diameter plastic pipe. If you have AC then instead of the pipe, this is where the air conditioner is located, between fan and heater. This is the fan assembly. Air enters from the plenum under the cowl on the upper right and exits the fan on the left. The wiring is to the coiled resisters that give the fan it's 3 or 4 speeds. 1 Quote Link to comment
wayno Posted April 15, 2018 Report Share Posted April 15, 2018 If 4wd it could be console gauge wiring/plug? What color is the plug/connecter, white, black? 1 Quote Link to comment
datzenmike Posted April 15, 2018 Report Share Posted April 15, 2018 That would be tucked up under the dash on the right side of the heater not under the glove box. That's were mine was. 1 Quote Link to comment
Lockleaf Posted April 17, 2018 Report Share Posted April 17, 2018 There also may be a couple loose connectors from the ac setup. Post pics man. 1 Quote Link to comment
