MIKEYFTW Posted April 12, 2018 Report Share Posted April 12, 2018 My cigarettes lighter isn’t working but the dome light is. Checked the connections and everything is plugged in. It was working and now seems to have just died. 1 Quote Link to comment
datzenmike Posted April 12, 2018 Report Share Posted April 12, 2018 Try another one. 1 Quote Link to comment
Dolomite Posted April 12, 2018 Report Share Posted April 12, 2018 Check wires for power and proceed as warranted. 1 Quote Link to comment
banzai510(hainz) Posted April 12, 2018 Report Share Posted April 12, 2018 just trace the hot wire back / Usually its the common fuse, dome light door buzzer ect...... I had a wire broke loose on back of the fuse box where they was one wire still attached and one broke off which confused me for abit why one item was working and not another. also loose or corrossion on the connection under the glove box. or pin pushed in 1 Quote Link to comment
datzenmike Posted April 12, 2018 Report Share Posted April 12, 2018 The easiest thing to do is try lighter in another vehicle. If confirmed good operation, then.... Lighter base must be tightly secured so it is well grounded. I have to assume you checked for power? 1 Quote Link to comment
banzai510(hainz) Posted April 12, 2018 Report Share Posted April 12, 2018 oH i ASSUMED HE CKED FOR 12VOLTS AT THE WIRE 1 Quote Link to comment
Charlie69 Posted April 12, 2018 Report Share Posted April 12, 2018 Good time to quit smoking and make it a USB charging port for your phone. 3 Quote Link to comment
MIKEYFTW Posted April 12, 2018 Author Report Share Posted April 12, 2018 There is no 12v power from the cigarette lighter port I mean, not the cig lighter itself. It’s kind of impossible for me to drive and use gps without having my phone plugged in. I’ll trace the wires again and report back. 1 Quote Link to comment
Crashtd420 Posted April 12, 2018 Report Share Posted April 12, 2018 There is no 12v power from the cigarette lighter port I mean, not the cig lighter itself. It’s kind of impossible for me to drive and use gps without having my phone plugged in. I’ll trace the wires again and report back. So how are you verifying no 12volts? Test light or that fact your phone won't charge? Have you checked the charger too, sometimes the ones that plug into a cigarette light have a fuse inside them.... 1 Quote Link to comment
abbylind Posted April 12, 2018 Report Share Posted April 12, 2018 https://media1.tenor.com/images/87aa5445448859125695ec49d02de4a9/tenor.gif?itemid=11562877 1 Quote Link to comment
datzenmike Posted April 13, 2018 Report Share Posted April 13, 2018 So it's not the cigarette light we're talking about at all???????? My cigarettes lighter isn’t working but the dome light is. Checked the connections and everything is plugged in. It was working and now seems to have just died. 2 Quote Link to comment
