2one8 Posted April 9, 2018 Report Share Posted April 9, 2018 So I have some wheels from a previous project that never got used, they are 18x10.5 with really low offsets. Due to the low offsets they are proving to be very difficult to sell. Well I'm also starting a 1976 620 LWB project that I want to come out similar to this photo... low to the ground, wide wheels with meaty rubber. The wheels in the photo are 15 inch with 275/60 tires. Those come out to 711 mm overall height. The 18s with a 295/40 would come out to 693 mm overall, so they would be slightly smaller overall. My question is, will 18's look too large on the truck? I can find photos of 18s on a 620, but they are all tucked in the wheel wells and I just cant visualize how 18s would look if they were wide. 1 Quote Link to comment
hobospyder Posted April 9, 2018 Report Share Posted April 9, 2018 That's swb though 1 Quote Link to comment
2one8 Posted April 9, 2018 Author Report Share Posted April 9, 2018 I know, wheelbase isn't going to matter. Quote Link to comment
banzai510(hainz) Posted April 9, 2018 Report Share Posted April 9, 2018 Too BIG!!!!!!!!!!!!!! 2 Quote Link to comment
hobospyder Posted April 10, 2018 Report Share Posted April 10, 2018 Also the build that that picture is from is a pretty intense build. I have the dude followed on ig and that rear suspension is crazy looking 2 Quote Link to comment
hobospyder Posted April 10, 2018 Report Share Posted April 10, 2018 Wait does anybody remember the dude that built flares out of a 55 gallon drum? What were those, 15s? 1 Quote Link to comment
Dolomite Posted April 10, 2018 Report Share Posted April 10, 2018 Meh...your truck, ruin it as you see fit. 3 Quote Link to comment
datzenmike Posted April 10, 2018 Report Share Posted April 10, 2018 Stock 620 tire diameter is 23" and 14" rim. You're going to 27" so yes it will look weird. 10.5" or more wide won't fit either so the truck will have to be raised or big ugly flares used. Tires and rims should fit the truck not the truck made to fit the tires and rims. Going from 23" to 27" on a 4.375 axle is the same as swapping in a 3.72 ratio diff. Better swap in a V6. Just because you have them doesn't mean they have to be used. This is the worst reason for using them. You will need power steering or get a gym membership now! 1 Quote Link to comment
flatcat19 Posted April 10, 2018 Report Share Posted April 10, 2018 Wide/low offset wheels on a king pin truck is bad, mmmkay? 3 Quote Link to comment
2one8 Posted April 10, 2018 Author Report Share Posted April 10, 2018 Man, tough crowd in here... Also the build that that picture is from is a pretty intense build. I have the dude followed on ig and that rear suspension is crazy looking Yeah I've followed as much as I can about it. Pretty bad ass build for sure. Meh...your truck, ruin it as you see fit. thanks for your helpful input Stock 620 tire diameter is 23" and 14" rim. You're going to 27" so yes it will look weird. 10.5" or more wide won't fit either so the truck will have to be raised or big ugly flares used. Tires and rims should fit the truck not the truck made to fit the tires and rims. Going from 23" to 27" on a 4.375 axle is the same as swapping in a 3.72 ratio diff. Better swap in a V6. Just because you have them doesn't mean they have to be used. This is the worst reason for using them. You will need power steering or get a gym membership now! Even going with a 15" wheel and 60 series rubber like in the photo is larger than factory sizes. The overall height isnt really what I'm concerned with, its the wheel size. the 15's look proportionally good, just worried 18's will look huge compared to the truck, even with the overall height being smaller than the 15" setup. The 18's were $3800 and just sitting in the boxes never used because the car they were bought for got wrecked before I could mount them, and because of the offsets (-30fr/-45rr) they are very difficult to sell, so I'd like to use them if I can otherwise I will probably have to take a huge hit and sell them for way too little $$. I'm not even sure yet if these offsets will work yet, I'm just trying to get some ideas. Truck is getting a built 515whp VQ swap. I will need a wide contact patch in the rear, and I'm swapping to S13 subframes, which also means shortening the axle and tubbing isnt an option nor is it practical for what I want out of the truck. And power steering is already figured out, no worries there. Wide/low offset wheels on a king pin truck is bad, mmmkay? Wont be king pin when I'm done with it. S13 front and rear subframes. 2 Quote Link to comment
datzenmike Posted April 10, 2018 Report Share Posted April 10, 2018 13 or 18's can still be the same diameter wheel, just the rubber is thinner. I'm used to lots of rubber on the rims and find large diameter rims with a rubber coating, look ...... different, is all. You're just going to have to cut the fenders to make this work and that is also too bad. I hope this project gets finished and the truck isn't lost. 1 Quote Link to comment
2one8 Posted April 10, 2018 Author Report Share Posted April 10, 2018 13 or 18's can still be the same diameter wheel, just the rubber is thinner. I'm used to lots of rubber on the rims and find large diameter rims with a rubber coating, look ...... different, is all. You're just going to have to cut the fenders to make this work and that is also too bad. I hope this project gets finished and the truck isn't lost. The truck will absolutely get finished. May take me a long time, but it will get done. Sourcing S13 subframes right now, have a S14 diff with LSD lined up, if everything fits like I'm thinking it will I already have a carbon driveshaft the correct length, wiring, ECU, fuel... everything is pretty much here and ready, I just need to get it started but the damn snow wont stay away to get the truck moved around. Progress will be posted once I get to start it. Now, back to the wheels, when I say wheel I'm referring to the "rim" itself, not including the tire. So yes, you can absolutely change the overall diameter by changing the sidewall of the tire. Thats why I say an 18" wheel with a 40 sidewall tire has a slightly smaller overall diameter than the wheels/tires that I posted above. I know the 15inch wheels look good above, I just cant picture that size overall diameter with a 18 inch wheel instead of a 15 inch wheel. I'm afraid the 18's will look huge, much like when someone tries putting 20's on a Honda Civic, they look way bigger than they actually are because the car is so small. Hopefully this photo links correctly. The wheels/tires in this photo are 18x10.5 wheels, with 295/40 tires. I dont think its too much rubber for the wheel and think this is a perfect combo for a 18 inch wheel. Maybe I will just have to photoshop this onto a 620 and see how it would look? And no, I wont do a universal flare like those on the truck lol 1 Quote Link to comment
Stoffregen Motorsports Posted April 10, 2018 Report Share Posted April 10, 2018 One aspect not often thought of is proportions. The scale of the proportions has to go up or down according to certain variables. A tire that wide on a rim with that offset will make the truck damn near as wide as it is long, making it act weird and drive funny. Agreed 100% with flatcat. Huge negative offset wheels do many bad things to suspension geometry and durability. 1 Quote Link to comment
flatcat19 Posted April 10, 2018 Report Share Posted April 10, 2018 Durability was my largest concern. With a build as described...this wheel combination just doesn't fit in the grand scheme of the end result. Your car, your money. 1 Quote Link to comment
datsunfreak Posted April 10, 2018 Report Share Posted April 10, 2018 My question is, will 18's look too large on the truck? I can find photos of 18s on a 620, but they are all tucked in the wheel wells and I just cant visualize how 18s would look if they were wide. As said, you won't find pics because it's really not a good look, and rough on the suspension. I really like 18s on a 620, if they are tucked... 3 Quote Link to comment
datsunfreak Posted April 10, 2018 Report Share Posted April 10, 2018 I believe this one is wearing 17s... 2 Quote Link to comment
datsunfreak Posted April 10, 2018 Report Share Posted April 10, 2018 While these are 16s, this is probably about the look you'd end up with... 3 Quote Link to comment
datzenmike Posted April 11, 2018 Report Share Posted April 11, 2018 You'll just have to put flares on. Cutting the stock wheel arches will destroy the looks and structural strength. The picture you posted shows an unsightly radius cut to follow the tire. The front won't be any better looking. Tires should fit the truck not the truck fit the tires. 1 Quote Link to comment
Stoffregen Motorsports Posted April 11, 2018 Report Share Posted April 11, 2018 In the offroad world, it is not uncommon to build the truck around the tires, but that;s where the proportion comment I made earlier comes into play. If you want t use 42" tires, then the wheelbase and track width need to be "X". Same for the wide ones in the first pic here. The truck is too short for that wide of a stance. Fender cuts can be made to look good and retain strength, but I rarely see it done right. Guys usually just hack it out and call it done. 3 Quote Link to comment
Hawaiian620 Posted April 30, 2018 Report Share Posted April 30, 2018 Speaking of offsets would a 15in wheel with -12 offset and 9in wide tires look funny/need flares? I saw his are -30. Just asking for a friend... 2 Quote Link to comment
datsunfreak Posted May 1, 2018 Report Share Posted May 1, 2018 Speaking of offsets would a 15in wheel with -12 offset and 9in wide tires look funny/need flares? Depends. Do you care if it rubs? A lot? ^_^ 1 Quote Link to comment
flatcat19 Posted May 1, 2018 Report Share Posted May 1, 2018 http://community.ratsun.net/topic/14950-show-off-your-truck-wheels/ Tire fitment on all the trucks with different wheel combinations has been talked about a lot around here. Start with that thread. Lots of the pics are broke, but the info is still present. 2 Quote Link to comment
Hawaiian620 Posted May 1, 2018 Report Share Posted May 1, 2018 Depends. Do you care if it rubs? A lot? ^_^ More rubbing than a slight fender rolling would take care of? If so then nevermind haha It'll be on a 620 with 3in blocks and 720 springs if that helps figure out the rubbing. I saw flatcat say +10 is even with the fender so maybe that's the way to go 1 Quote Link to comment
distributorguy Posted May 7, 2018 Report Share Posted May 7, 2018 218, come down to my shop on some Thursday night (Bonneville build night) and see what it took to make our wheel and tires fit (still only 15, but extreme lowering) to get an idea of the amount of fab involved. Ours included rebuilding the clutch pedal, changing the inner wheel arch dramatically, and changing the clutch throw to be able to function in less space. The other issue no one mentioned with wider tires is that tire scrub is already bad, and amplified the wider you go. This means you'll find yourself steering the car into corners, and steering it back out of corners. It won't want to "return to center" the way it used to. It makes driving a little more of a chore, unless you add power steering. That's all required so the tires don't rub. Its doable for sure, but more work than you might expect. 2 Quote Link to comment
datzenmike Posted May 8, 2018 Report Share Posted May 8, 2018 Run tires that are narrower on the front. It's an old trick that gives the illusion the rears are wide than you think. 1 Quote Link to comment
