Jack1950 Posted April 4, 2018 Report Share Posted April 4, 2018 Went to replace my strut rod bushings and the cups the bushings sit in have worn out and broken off. Anyone have a solution?? It is by the arrow on the left, the bushing cup is spot welded to the bracket the rod goes thru.. The cup keeps the bushing centered so the rod stays centered. Any help much appreciated. 1 Quote Link to comment
Lockleaf Posted April 4, 2018 Report Share Posted April 4, 2018 I've taken the washer on the outside of the bushings, flipped it around and welded it on to the truck. New bushings come with new washers. 1 Quote Link to comment
Jack1950 Posted April 4, 2018 Author Report Share Posted April 4, 2018 Thanks, I will give that a try. The hole in the center will have to be drilled out. Thanks for the suggestion. 1 Quote Link to comment
