Velict Posted March 27, 2018 Report Share Posted March 27, 2018 Is it confirmed that the H89 head will fit the late mode ('80 - '89) A12S engine? Also, what is the price point for one, or should I just get my original head worked? Quote Link to comment
Morrisun Posted March 28, 2018 Report Share Posted March 28, 2018 I have not hear of a A12s, an A12A was available in North America from 80-82 in Datsun 210's, mostly the engines were in cars imported to Canada. H89 is a very good flowing head for low and mid range rpms, GX heads flow better at high rpm- 8,000 and higher. H89 came on A15 engines not imported in cars to usa but some have found their way to A series engine freaks. (Lots of JDM imported A15 engines were available) A15's had 76mm pistons, so you will have to check your bore size and camshaft/valve lift as H89 have 37/30 valves where A12 had 35/29 vales as they had to clear 73mm bore in the A12's. For what it's worth, if you do have an A12a, they have a stock bore of 75mm and can be bore to 77mm, sometimes with sonic testing of cylinder liners perhaps 78mm. H89 heads come-up for sale on ebay from time to time, you may list in the Ratsun want ads. Quote Link to comment
Velict Posted March 28, 2018 Author Report Share Posted March 28, 2018 The A12s is just the mid-mounted A12 (stock) late model. I will bore the A12 to 76mm, work the H89 head, and mount it. Quote Link to comment
