A12S Head Swap to H89 Head
Velict
  • Replies 2
I have not hear of a A12s, an A12A was available in North America from 80-82 in Datsun 210's, mostly the engines were in cars imported to Canada.
H89 is a very good flowing head for low and mid range rpms, GX heads flow better at high rpm- 8,000 and higher.
H89 came on A15 engines not imported in cars to usa but some have found their way to A series engine freaks. (Lots of JDM imported A15 engines were available)
A15's had 76mm pistons, so you will have to check your bore size and camshaft/valve lift as H89 have 37/30 valves where A12 had 35/29 vales as they had to clear 73mm bore in the A12's.
For what it's worth, if you do have an A12a, they have a stock bore of 75mm and can be bore to 77mm, sometimes with sonic testing of cylinder liners perhaps 78mm.
H89 heads come-up for sale on ebay from time to time, you may list in the Ratsun want ads.
