Z22 Crankshaft pulley on L20B?
  • Replies 4
Not the same but will fit. I've used Z series alternator brackets on L series engines so the belts line up. Different diameter pulleys maybe.
So would I need the alternator braket too? I'm in a pickle right now since my original cranshaft pulley has a crack, and the only local one I can find is for a z22. If I do need the alternator braket I don't really mind since more than likely I'll also need the a/c braket too if I swap the pulley into my 510.
