Where is the fuel pump relay on a 1985 nissan king cab 4x4?
bubba_doc
  • Replies 7
It's beside the glove box, above the passenger side kick panel, just out of sight. There will be a smaller brown or blue electric choke heater just below it. The fuel pump relay is larger.
Here... https://axleaddict.com/auto-repair/The-Datsun-and-Nissan-Pickup-Fuel-Pump-Relay-What-the-Haynes-Automotive-Repair-Manual-Wont-Tell-You
Just in case you need to replace it, the Nissan part # is 28545-89900.
You would have to call a dealership to see if they are still available.
  • 2 weeks later...
Post a want ad... http://community.ratsun.net/classifieds/category/3-datsun-parts/?sort_key=date_added&sort_order=desc... buying and selling have to be done there.
The tail light reflectors from Oct. '83 and up build dates should interchange through to the end of the 720, even though the beds changed for '85. 2wd  and 4x4 lenses are different, probably something cosmetic, and should fit but won't match side to side.
  • 1 month later...
