Kingcab Posted February 25, 2018 Report Share Posted February 25, 2018 Need help figuring out why the engine will start right up runs and idles fine for about 45 seconds then dies.. then I have to wait about 20 minutes and it start a back up and runs for 45 seconds then dies again.. Quote Link to comment
Kingcab Posted February 25, 2018 Author Report Share Posted February 25, 2018 The car has been sitting for about 10 years I guess.. I just got the car with no background info other than it was last driven 2008. The engine starts up just fine first try and sounds strong! But it only idles for about 45 seconds then dies.. I have to wait about 20 minutes before it will start up again then it dies about 45 seconds... the fuel pump is bran new and so is the fuel filter. Quote Link to comment
Doctor510 Posted February 25, 2018 Report Share Posted February 25, 2018 Check the fuel filter(s) and the condition of the gas Quote Link to comment
datzenmike Posted February 25, 2018 Report Share Posted February 25, 2018 Did you check for spark when it won't start? Probably not it, but saves running around looking at fuel as the cause. When I won't start can you hear the fuel pump working???? Quote Link to comment
Dolomite Posted February 26, 2018 Report Share Posted February 26, 2018 Will it run if you give it throttle or pump the accelerator? The carb is probably junked up. Quote Link to comment
