Can NISMO racing head gaskets be used on a street A14
datsoonlovr
I recently purchased Nismo racing head gaskets for me A14 engine.  When I received the gaskets it had a sticker on the package saying basically "not for street use".  I thought that the racing gaskets would be  a better quality then the FelPro gaskets that I had previously used.  Any one had any experience with these head gaskets???  Thanks  Jim
  • Replies 7
I've run the Nismo L-series gasket on the street with no issues,
and my 95% street driven Toyota only gets all metal head gaskets, because of the 12:1 compression ratio, and have never had a problem with those.
You just have to make sure the gasket surfaces are flat, and smooth.
To clarify which Nismo gasket; there is the GX head gasket .8 crush thickness and the race gasket which is .6 crush thickness. Use an online compression calculator to figure compression ratio. Note the both the gaskets have 79mm bore (stock is 76) it has not erect other than on compression ratio.
We used the GX gasket for something like 10 seasons with no issue whatsoever.
Depending on what pistons and what head you have the compression ratio could be as high as 10.5-1 but it's more likely to be around 9.8-1
