Alternative dizzy cams
mainer311
If only gain is loosing points then go to junk yard and get an EI dizzy and matching coil.
If my points are loosing, I should probably tighten them, eh?
Is reading comprehension on this forum really this bad? How many times did I say I now have a matchbox w/ pedestal coming?
  • Replies 69
I have a long, long history with loose and lose, just ask flatcat. :lol:
Just received a matchbox dizzy from a fellow rat on the west coast. Picked up a 0.70 ohm MSD Blaster 2 coil (overpriced yes, but we were having trouble finding another coil in the right range). Should be all set now.
Someone will have one.
I went to drop the dizzy in, and the vac advance unit is so big that it’s a super tight fit against the upper rad hose. I ended up rotating it 180, but now the matchbox is by the exhaust manifold. I wonder if there is some way to fab up a heatshield.
The L-bracket on the bottom doesn’t really allow for that. The two arms on the L are different lengths so they can’t line up with both the hole in the housing and the hole in the pedestal.
I can flip it over, but that gets me back to 180.
