Steering hub adapter
Dirtyowlnumber4
  • Replies 6
There are 2 different sizes for 6 bolt steering wheels.
Be weary.
eBay should have what you need after you figure out your bolt pattern.
EDIT: There are 2 BOSS hubs on eBay right now for the B210. The BOSS hub has patterns for both 6 bolt sizes.
Did you even try to look before asking?
Yah I bought one on ebay for a b210 and it didn't fit onto the column then I tried one for some 80s Nissan don't quite remember which one. The universal one from the parts store didn't fit either. figgered I should stop buying 50 dollar adapters that don't fit.
Just checking to see if there was a particular type yall are gettin
Grant lists the #4590 as fitting, but that's 3 hole. Adapters can be had to fit 5 or 6 hole applications.
I could be wrong, but I believe the B210 and a 510 has the same size splines. NRG SRK-142h.
But, stated in first post, you don't even know what you have.
