Datsun 510 2 door sedan "SHAKOTN"
five1oh
........................................so i did a thing................................
After much thought and work on my taillights I decided with as NICE as this car is turning out I was really getting bummed about installing the lights I had.......don't get me wrong they are super nice and would've been fine but I had to fix a bunch of mounts, create my own rubber gaskets, and I wasn't feeling good about it.  When a NOS set came up for sale I could not resist.  Probably not the best financial decision but they are DEFINITELY worth EVERY penny.
Untitled by five1oh2010, on Flickr
26785545597_bf7c5769e0_k.jpgUntitled by five1oh2010, on Flickr
I probably paid less for my first house than you paid for those taillights. :rofl:  The car looks awesome.
  • Replies 554
Thanks everyone for the kind words.  I can't wait to start driving it.
So Eric finished painting my wiper cowl, gas door, and 1/4 windows.  Yesterday he drove down to help me start assembling the engine.
26871598527_7b170a4e8b_k.jpgUntitled by five1oh2010, on Flickr
26871590327_97a024b99f_k.jpgUntitled by five1oh2010, on Flickr
41739923051_80290cef7b_k.jpgUntitled by five1oh2010, on Flickr
40840699715_fb8f587886_k.jpgUntitled by five1oh2010, on Flickr
41022171374_fb30bd3882_k.jpgUntitled by five1oh2010, on Flickr
27870673648_4e65176ed2_k.jpgUntitled by five1oh2010, on Flickr
Wiper cowl and gas door installed.  I still need to remove all the stickers from the 1/4 windows and install the weatherstripping:
40840690595_40f155dfba_k.jpgUntitled by five1oh2010, on Flickr
39932302080_edf7facd1a_k.jpgUntitled by five1oh2010, on Flickr
41022208434_ddba123153_k.jpgUntitled by five1oh2010, on Flickr
41022192204_752181d3f0_k.jpgUntitled by five1oh2010, on Flickr
41022171434_b01c43f055_k.jpgUntitled by five1oh2010, on Flickr
26871607667_95b4d614d6_k.jpgUntitled by five1oh2010, on Flickr
26871593197_6d80adba54_k.jpgUntitled by five1oh2010, on Flickr
41699120892_1cd149e718_k.jpgUntitled by five1oh2010, on Flickr
Motor time  :)
40840677045_887131d690_k.jpgUntitled by five1oh2010, on Flickr
39932334230_055fc7a336_k.jpgUntitled by five1oh2010, on Flickr
39932307480_55f3b4622e_k.jpgUntitled by five1oh2010, on Flickr
41022217084_2310e73b6a_k.jpgUntitled by five1oh2010, on Flickr
Cleaning and more cleaning:
39932349340_b8e0a9bfe1_k.jpgUntitled by five1oh2010, on Flickr
41739962231_42ec765f32_k.jpgUntitled by five1oh2010, on Flickr
39932333850_c81037a349_k.jpgUntitled by five1oh2010, on Flickr
41022173654_4b72709d43_k.jpgUntitled by five1oh2010, on Flickr
I removed all of the old valves and found some bent ones so I also removed all the valves from my N42 head that will be used on the skyline.  Since I am buying mostly new parts for that motor we picked the best valves and parts we could:
27870678338_d1ebb07461_k.jpgUntitled by five1oh2010, on Flickr
41022190534_617242576d_k.jpgUntitled by five1oh2010, on Flickr
27870672918_49faa6acd6_k.jpgUntitled by five1oh2010, on Flickr
41022189014_416455f0fe_k.jpgUntitled by five1oh2010, on Flickr
Next step was lapping the valves.
26871605057_4c2c73043f_k.jpgUntitled by five1oh2010, on Flickr
40840688495_e73a3c0406_k.jpgUntitled by five1oh2010, on Flickr
41699119872_40b0985655_k.jpgUntitled by five1oh2010, on Flickr
New valves and springs installed:
41022210774_4ca48ee516_k.jpgUntitled by five1oh2010, on Flickr
39932319940_cc3fea212f_k.jpgUntitled by five1oh2010, on Flickr
Head installed and the new 63di Rebello cam:
40840676275_f43b26640a_k.jpgUntitled by five1oh2010, on Flickr
27870666338_f5ac6f744d_k.jpgUntitled by five1oh2010, on Flickr
That's all for now
  • Like 3
The valve divots/point of impact on the top of the pistons aren't going to cause an issue?
This car was supposed to be a.............wait for it........budget build **cough cough**.    Just a quick spray job and assemble................as you can see I got a little carried away.  So to answer your question this motor ran great in my other car (search "wanabre") but leaked like a sieve....front, back, sides, you name it.  It ran strong and didn't smoke.  It definitely was built with some go fast parts but obviously wasn't well put together.......gasket maker instead of gaskets, silicone all over, etc. etc,
So the plan was to pull apart and reseal while replacing the cam.  Unfortunately I had some bent valves so I had to replace with some good used ones.  Pistons were not removed.  Prior to disassembling we did leak down and compression tests and they came out good.  The only purchased parts were seals, timing kit, springs, and cam (lash pad were good).....and some external parts (fuel pump, water pump, thermostat housing, etc.).  I used the best borrowed parts from other motors.  There was also no machining done on this build.
Hope this answers your question
Your order confuses me. :rofl:
I mentioned the problem with the radiator and grill and got nothing, but now I have to ask about installing the wiper cowl without the wipers?
I guess it's a case of I wanted to see how it looked LOL. I know I need to remove both. I have the wiper pivots but am still waiting on the linkages from Japan. The grill needs to come off to be touched up and to install the correct bolts behind it. Not to worry some future pics will likely show that it has magically been done hahaha
Nickle&dime no clue on the pistons.... 89mm though. Motor will be 2140cc
small updates - painted my steering arms, cleaned off and installed rear coilovers, and spent about an hour chatting with Craig Ford getting my harness labeled and understanding where all the plugs went to.  It was pretty self explanatory looking at the plugs and colors of wires but it was great to get confirmation on some questions I had.  Thanks Craig!
41111734394_17abb7f43c_k.jpgUntitled by five1oh2010, on Flickr
40021402870_46b6c9500f_k.jpgUntitled by five1oh2010, on Flickr
26960368827_f442f9bdaf_k.jpgUntitled by five1oh2010, on Flickr
40021379800_4c1108036c_k.jpgUntitled by five1oh2010, on Flickr
41827925111_49dc2a7779_h.jpgUntitled by five1oh2010, on Flickr
41786096292_2c29235771_h.jpgUntitled by five1oh2010, on Flickr
41786096312_f23ea89b28_h.jpgUntitled by five1oh2010, on Flickr
41786095782_7cc5e7cbbb_h.jpgUntitled by five1oh2010, on Flickr
40021361120_40de733bc8_h.jpgUntitled by five1oh2010, on Flickr
27959980458_97fe53ecd1_h.jpgUntitled by five1oh2010, on Flickr
Pretty sure I have the same rear coilovers. Curious about not having a locking set screw, clamping collar or second collar to "double nut." Have you used these before, any slippage, thoughts, etc.... Mine is just sitting for the time being and I've been wondering about the ProShock setup.
Also, beautiful build! The color choice and attention to detail are spot on. I hope you drive this thing hard, it's lovely and deserves to be anything but a trailer queen!!! Given your enthusiasm, I don't think it'll sit much.
These came of of my "wanabre" car.  They are pretty bouncy but work.  I was going to by a new setup from Ermish for the rear on this car but I am broke.....maybe later.  The collar has the ability to have a locking set screw but there is not one installed.  I ran these on "wanabre" for a year with no issue....I will probably find a set screw and use it on this car though.
Thanks for the kind words.....this WILL be a driver.  I drove 650 miles so far this week and only 50 miles were in my beater '92 Integra........the other 600 miles were in my '70 FairladyZ ("s30 ldy" in the build thread).  What is the point of owning these cars if you don't drive them??
My White '69 510 (nicest one I ever had....before this one) was my daily driver/commuter for 18 months.
Doctor510 - on the motor questions I don't know the answers - don't know how to make flat top pistons out of dished - motor is a L20b block and I am unsure of the crank, I am guessing stock but I don't know.
Exciting stuff!  Front suspension is back ON!  I went to Troy Ermish's last week and picked up my RHD Idler Arm with NEW delrin bushing installed, picked up my RHD drag link with new joint installed and steering ends drilled out to 5/8".  Also picked up his rod end steering kit.  For those that don't know this will be coupled with the setup I already had on the "wanabre" car:
- 280zx strut tubes with weld in coilovers
- short Eibach springs (might be too short.....we will see)
- 280zx front discs
- T3 camber plates
- T3 TC Rods
- T3 adjustable lower control arms
- Troy Ermish bumpsteer spacers
40081701290_43b65fe756_k.jpgUntitled by five1oh2010, on Flickr
40989996355_4c99bdf50a_k.jpgUntitled by five1oh2010, on Flickr
41845929132_45c9e72ac4_k.jpgUntitled by five1oh2010, on Flickr
28019165378_da98ad4109_k.jpgUntitled by five1oh2010, on Flickr
41888823361_bb2d0dcf51_k.jpgUntitled by five1oh2010, on Flickr
41888824001_20285254e0_k.jpgUntitled by five1oh2010, on Flickr
40081687310_c7c7f6560b_k.jpgUntitled by five1oh2010, on Flickr
41888807961_f8422fb37a_k.jpgUntitled by five1oh2010, on Flickr
41888823371_747c37fb5a_k.jpgUntitled by five1oh2010, on Flickr
27020642047_177fa0d587_k.jpgUntitled by five1oh2010, on Flickr
28019148628_0a94f9682b_k.jpgUntitled by five1oh2010, on Flickr
40989965535_922dbe664e_k.jpgUntitled by five1oh2010, on Flickr
41845928212_119f754c20_k.jpgUntitled by five1oh2010, on Flickr
41888807761_197bfcce9d_k.jpgUntitled by five1oh2010, on Flickr
I still need to installed the Rod End Steering kit
I installed the hood trim on my car, put one 1/4 window weatherstripping on, and modified my brake setup to fit (I had to shave down the booster to body bracket to fit above the column cutout and I had to bore out the booster to master bracket to accept the 7/8" brake master cylinder I am running.  Big thanks to my friend Ralph for boring the bracket.
27020638957_b47385e1b0_k.jpgUntitled by five1oh2010, on Flickr
41888832061_8b3f759633_k.jpgUntitled by five1oh2010, on Flickr
28019152548_f1350bd3a8_k.jpgUntitled by five1oh2010, on Flickr
41171547544_6230c30ae1_k.jpgUntitled by five1oh2010, on Flickr
41888816331_9b526ee539_k.jpgUntitled by five1oh2010, on Flickr
40081700970_c76d332dd4_k.jpgUntitled by five1oh2010, on Flickr
41171560864_f27aadfd88_k.jpgUntitled by five1oh2010, on Flickr
  • Like 4
Brake lines and clutch line.....................DONE!!!!  My friend peter helped (or should I say he did) while I provided moral support and helped route the lines.  While we were out trying to find line and fittings we could not find any 25ft steel rolls.....but we did find this copper alloy that looks sweet!  I am happy with the way they were run as this was my first time ever doing this.  They could be cleaner but I am very happy with the result.  We were able to hide some lines behind the steering box brace.  They will get the job done.
First task was mounting the brake bracket, booster, master, and clutch master.  We had to shorten the input shafts on both as they contacted the pedals.
27084157617_a1e88282ce_k.jpgUntitled by five1oh2010, on Flickr
41054012215_7a1d9ce7e3_k.jpgUntitled by five1oh2010, on Flickr
40146281830_418b24af5b_k.jpgUntitled by five1oh2010, on Flickr
41234829564_ec23af719e_k.jpgUntitled by five1oh2010, on Flickr
41054030845_75f2928ea5_k.jpgUntitled by five1oh2010, on Flickr
27084175907_3fa7296309_k.jpgUntitled by five1oh2010, on Flickr
27084173387_a61eb46d12_k.jpgUntitled by five1oh2010, on Flickr
40146273150_27f54a7b0e_k.jpgUntitled by five1oh2010, on Flickr
41234820034_aa7fde685a_k.jpgUntitled by five1oh2010, on Flickr
28082069198_d291676915_k.jpgUntitled by five1oh2010, on Flickr
28082068678_a4498f6b55_k.jpgUntitled by five1oh2010, on Flickr
41234818084_7324cb1421_k.jpgUntitled by five1oh2010, on Flickr
40146264270_d14a917495_k.jpgUntitled by five1oh2010, on Flickr
41234811374_ba93bfd4e0_k.jpgUntitled by five1oh2010, on Flickr
41234811764_637d24167a_k.jpgUntitled by five1oh2010, on Flickr
41234812254_02ff46b575_k.jpgUntitled by five1oh2010, on Flickr
27084160097_965fd69ef8_k.jpgUntitled by five1oh2010, on Flickr
So the more I looked at the engine bay the more I disliked my brake line routing so I decided to redo them.  This time I changed out the clutch master with a friends so that the line came out the side.  I also relocated the rear line to go straight under the car instead of crossing sides, and I moved the passenger side brake line to route under the radiator.  VERY HAPPY I changed it before motor install even though I had to spice in to extend the passenger line.  Maybe down the road I will remake it completely
41097287535_83163f8cc9_k.jpgUntitled by five1oh2010, on Flickr
41952743452_f63080e357_k.jpgUntitled by five1oh2010, on Flickr
27127807247_528ecc9578_k.jpgUntitled by five1oh2010, on Flickr
41278064454_c362b75f67_k.jpgUntitled by five1oh2010, on Flickr
41952752402_16f9d3b3ef_k.jpgUntitled by five1oh2010, on Flickr
40190048990_ba99c92940_k.jpgUntitled by five1oh2010, on Flickr
My friend Peter came over yesterday to install my headliner for me........THANK YOU SO MUCH PETER!!!!!!!!!!!!  We didn't quite finish but got a long way in the right direction.  I pulled out my glass while Peter started on the headliner........I bought this rear window a year ago and TOTALLY forgot it looked like this........holy crap.  So I spent about an hour scraping and removing glue.  I also laid out the weatherstripping in prep for install.
41097287395_20cb87886a_k.jpgUntitled by five1oh2010, on Flickr
41278045054_41763cf29c_k.jpgUntitled by five1oh2010, on Flickr
41278058884_9de0bd6d06_k.jpgUntitled by five1oh2010, on Flickr
28125373738_5445217a60_k.jpgUntitled by five1oh2010, on Flickr
In other news I got my front steering kit installed from Troy Ermish!  So awesome!  I think I installed it correctly but will follow up with Troy today to make sure.  It looks so GOOD!
27127807767_82d82b0257_k.jpgUntitled by five1oh2010, on Flickr
28125384648_0e4e894e2f_k.jpgUntitled by five1oh2010, on Flickr
28125373218_fc877fab8c_k.jpgUntitled by five1oh2010, on Flickr
27127809257_a295b00b68_k.jpgUntitled by five1oh2010, on Flickr
41996884201_68058d5940_k.jpgUntitled by five1oh2010, on Flickr
