Datsun 510 2 door sedan "SHAKOTN"
five1oh
Nice how did you install the 1600 badge on the back?
It's the eBay one. I have a real 1800sss one with the prongs but didn't want to install it. The eBay one comes with 3M double stick tape on the back.
  • Replies 554
Installed my other pillar vent however I will be switching screws since these ones I feel are slightly too big for the holes.  I have only one that is the right size that I will be matching.  I also installed my freshly painted interior trim moldings.
41538236471_079c032b0a_o.jpgUntitled by five1oh2010, on Flickr
40826337684_ab4e77313a_o.jpgUntitled by five1oh2010, on Flickr
26669367377_bdde8ba15f_o.jpgUntitled by five1oh2010, on Flickr
26669367097_14d65c5e46_o.jpgUntitled by five1oh2010, on Flickr
26669367337_f153c58738_o.jpgUntitled by five1oh2010, on Flickr
26669367217_52b979dd37_o.jpgUntitled by five1oh2010, on Flickr
40645044675_dbd76b7d55_o.jpgUntitled by five1oh2010, on Flickr
Decided to start installing my harnesses.......to be honest I am a little overwhelmed as I have/had no clue where things go.  After unravelling the factory bends (LOL) started to take shape and guide me with what to do.  Then I started grabbing my accessories like gauge cluster, steering column cover, signal switch, heater defroster, etc, etc.  Most of the plugs I started to match but there are still a bunch I need to figure out.  Wiring is NOT my strength.
First thing I did was clean off the harnesses with some simple green and I installed the fuse box.  As an FYI i purchased P510 harnesses for the whole car.  While my car has a lot of higher end SSS options and with me wanting to install some other factory add ons from other cars it will take me some time to figure out.  For instance I want to use my lighted switches from 1973 since I heard the 1800SSS coupe had them.  The plug for the wiper switch will work but the headlight switch has a different plug but the same amount of wires....hopefully I can figure it out but I may have to run the Japan switch since those cars had different parking light switched and flash to pass etc etc.
If anyone has a Japanese P510 wiring diagram it would be super helpful.  Anyways on to the pics!
40645050425_583e944fc7_o.jpgUntitled by five1oh2010, on Flickr
40645044515_5c5f5f3774_o.jpgUntitled by five1oh2010, on Flickr
40826339444_f0d52e3b26_o.jpgUntitled by five1oh2010, on Flickr
Because I am broke I used my 1973 backlit heater panel but it wouldn't fit so I had to cut off the light bucket....sorry guys:
26669372537_c02ee7346f_o.jpgUntitled by five1oh2010, on Flickr
26669372807_5d0b1c5e67_o.jpgUntitled by five1oh2010, on Flickr
40645050795_935a29211b_o.jpgUntitled by five1oh2010, on Flickr
I have been saving this center section since high school  :thumbup:  :thumbup:  :)  :)  It is a perfect uncut piece with the factory blanks (obviously I will be running my foglight switch and more than likely a cigarette lighter but this is oh so cool).  Couple this with my factory map light switch and it will be perfect
40826348054_393d469457_o.jpgUntitled by five1oh2010, on Flickr
27668435508_8689c69daa_o.jpgUntitled by five1oh2010, on Flickr
40826340294_865bec2bdb_o.jpgUntitled by five1oh2010, on Flickr
Also going to run this super nice SSS gauge cluster.  Looks like my Skyline one  :rolleyes:
26669366627_1a0833e42b_o.jpgUntitled by five1oh2010, on Flickr
I have been wanting to install my hood latch release cable but needed the harness in to do so since it is routed through the top of the rubber grommet on the fire wall:
40826338804_51802331e6_o.jpgUntitled by five1oh2010, on Flickr
27668436718_86dd0d00c1_o.jpgUntitled by five1oh2010, on Flickr
40645050715_ab43fe8e04_o.jpgUntitled by five1oh2010, on Flickr
I had my daughter help me test it and it works perfectly  :cool:
  • Like 4
1/4 windows are ready for paint  :)
41610604872_599580c36a_k.jpgUntitled by five1oh2010, on Flickr
40939269334_73e685c55c_k.jpgUntitled by five1oh2010, on Flickr
40939269554_9aecebbf84_k.jpgUntitled by five1oh2010, on Flickr
I changed out the screws on the pillar vents......much better now.
26782375167_b56ce4b7c0_k.jpgUntitled by five1oh2010, on Flickr
I tucked the wire harness behind the steering column.  I still need to mount it with P clamps but still working on routing and understanding where everything goes.
40939302634_d25e4799ac_k.jpgUntitled by five1oh2010, on Flickr
I picked up my 63di cam from Rebello Racing along with new springs and a head gasket.  Motor is getting put back together on Thursday  :)  :thumbup:
27781565108_73f49a085a_k.jpgUntitled by five1oh2010, on Flickr
Front Bumper installed  :thumbup:
40939271034_49d7aa6976_k.jpgUntitled by five1oh2010, on Flickr
26782378327_7ca9ddf1e2_k.jpgUntitled by five1oh2010, on Flickr
26782378157_91c785c7d9_k.jpgUntitled by five1oh2010, on Flickr
While scouring for more hardware to mount my bumpers I revisited the front crossmember.  I knew that the hardware I placed there was incorrect so I decided to check my shell and it was awesome because I found the correct bolts AND mounting plates.  I cleaned them up and changed out the hardware on the car:
40939528674_e7f137b889_k.jpgUntitled by five1oh2010, on Flickr
39842913060_f8c1d4857f_k.jpgUntitled by five1oh2010, on Flickr
26782533127_ebe62dba5e_k.jpgUntitled by five1oh2010, on Flickr
27781718438_7a7824cf6c_k.jpgUntitled by five1oh2010, on Flickr
41610769562_197901325a_k.jpgUntitled by five1oh2010, on Flickr
Engine VIN ID tag mounted.  I am planning on stamping it but need to buy the stamps first:
27781715688_0f9f4655ad_k.jpgUntitled by five1oh2010, on Flickr
REAR BUMPER INSTALLED:  :w00t:  :)  :)  :)  :)  :)  :)  :)
40939516554_135547f0f1_k.jpgUntitled by five1oh2010, on Flickr
39842898740_55912d8e92_k.jpgUntitled by five1oh2010, on Flickr
39842894250_db8f5f05fe_k.jpgUntitled by five1oh2010, on Flickr
40939459564_6961f76cc6_k.jpgUntitled by five1oh2010, on Flickr
........................................so i did a thing................................
After much thought and work on my taillights I decided with as NICE as this car is turning out I was really getting bummed about installing the lights I had.......don't get me wrong they are super nice and would've been fine but I had to fix a bunch of mounts, create my own rubber gaskets, and I wasn't feeling good about it.  When a NOS set came up for sale I could not resist.  Probably not the best financial decision but they are DEFINITELY worth EVERY penny.
27784637258_9327cee37e_k.jpgUntitled by five1oh2010, on Flickr
26785544427_700e0982f8_k.jpgUntitled by five1oh2010, on Flickr
40762246765_69f508dd9d_k.jpgUntitled by five1oh2010, on Flickr
26785545597_bf7c5769e0_k.jpgUntitled by five1oh2010, on Flickr
40762246465_f46e354501_k.jpgUntitled by five1oh2010, on Flickr
41652740091_34f564a5ad_k.jpgUntitled by five1oh2010, on Flickr
41613581852_4818bda5d4_k.jpgUntitled by five1oh2010, on Flickr
26785549167_9bd9249246_k.jpgUntitled by five1oh2010, on Flickr
41652735471_952ff0aae9_k.jpgUntitled by five1oh2010, on Flickr
40762236515_cbaaed037b_k.jpgUntitled by five1oh2010, on Flickr
39845762590_a6c81f863f_k.jpgUntitled by five1oh2010, on Flickr
  • Like 3
39845762290_1c3d5941d4_k.jpgUntitled by five1oh2010, on Flickr
27784623148_72526ec27b_k.jpgUntitled by five1oh2010, on Flickr
40942395474_0d316f3485_k.jpgUntitled by five1oh2010, on Flickr
39845762570_4b628b2420_k.jpgUntitled by five1oh2010, on Flickr
41652732041_97715c9257_k.jpgUntitled by five1oh2010, on Flickr
40942395684_65320a9510_k.jpgUntitled by five1oh2010, on Flickr
27784623138_56542144ff_k.jpgUntitled by five1oh2010, on Flickr
41613527012_de56a4ca75_k.jpgUntitled by five1oh2010, on Flickr
26785494637_098f807e52_k.jpgUntitled by five1oh2010, on Flickr
41613527072_4c619f435a_k.jpgUntitled by five1oh2010, on Flickr
40762201215_b4b00ee2f7_k.jpgUntitled by five1oh2010, on Flickr
40942360644_7c3ec60968_k.jpgUntitled by five1oh2010, on Flickr
40762201145_f5c792ab8f_k.jpgUntitled by five1oh2010, on Flickr
39845730420_47bfa3a788_k.jpgUntitled by five1oh2010, on Flickr
39845730330_23be5fdfe4_k.jpgUntitled by five1oh2010, on Flickr
26785441037_ffbe3975b3_k.jpgUntitled by five1oh2010, on Flickr
41613477352_3eb0c0d5fa_k.jpgUntitled by five1oh2010, on Flickr
26785441127_50cb4b720e_k.jpgUntitled by five1oh2010, on Flickr
39845679680_eb91d31225_k.jpgUntitled by five1oh2010, on Flickr
41613477082_724878bb64_k.jpgUntitled by five1oh2010, on Flickr
41613477192_156985e1fd_k.jpgUntitled by five1oh2010, on Flickr
41613477302_1d7d40db3d_k.jpgUntitled by five1oh2010, on Flickr
41613477062_01dd1208dc_k.jpgUntitled by five1oh2010, on Flickr
40762095935_fb86760751_k.jpgUntitled by five1oh2010, on Flickr
40762086645_3e54ab08ce_k.jpgUntitled by five1oh2010, on Flickr
so I guess this means they are not NEW OLD STOCK anymore.............................
:w00t:  :w00t:  :w00t:  :yawn:  :yawn:  :yawn:  :thumbup:  :thumbup:  :thumbup:  :)  :)  :)
40762089535_f0e5bf15d8_k.jpgUntitled by five1oh2010, on Flickr
41652613851_196a4f0ebf_k.jpgUntitled by five1oh2010, on Flickr
41652614181_3b072fa2b1_k.jpgUntitled by five1oh2010, on Flickr
41652101871_12273f743c_k.jpgUntitled by five1oh2010, on Flickr
40941515394_7472e02451_k.jpgUntitled by five1oh2010, on Flickr
41652029771_3f61800f3c_k.jpgUntitled by five1oh2010, on Flickr
27783850938_7d9db1392a_k.jpgUntitled by five1oh2010, on Flickr
40761348065_64b4753159_k.jpgUntitled by five1oh2010, on Flickr
41612905272_afe97838f1_k.jpgUntitled by five1oh2010, on Flickr
40941515704_f5581bea7d_k.jpgUntitled by five1oh2010, on Flickr
27783807368_c8b252a0fb_k.jpgUntitled by five1oh2010, on Flickr
  • Like 6
Time to paint my calipers.........one thing I never knew when I got them is that they needed to be painted.  I thought the gray color WAS paint and ran them on WANABRE for a year.  When swapping to this car I noticed they had started to get surface rust so cleaned them up with a wire brush and painted them with high temp black paint.  While I was working on the rear I pulled my halfshafts to give them a coat of paint as well.  I know I have at least one bad U-Joint so that will be getting replaced before re-installation:
40758872965_2458b4b828_k.jpgUntitled by five1oh2010, on Flickr
41632215622_4165e01ccc_k.jpgUntitled by five1oh2010, on Flickr
39864751410_64baa05afe_k.jpgUntitled by five1oh2010, on Flickr
39864756110_443e365283_k.jpgUntitled by five1oh2010, on Flickr
40781350555_f9b467bdb6_k.jpgUntitled by five1oh2010, on Flickr
41671041971_94532c7336_k.jpgUntitled by five1oh2010, on Flickr
27803109618_ae8f493bde_k.jpgUntitled by five1oh2010, on Flickr
CAN"T GET ENOUGH OF THAT REAR END!!!!!!!!!!!!!!
41671022291_b89363edc3_k.jpgUntitled by five1oh2010, on Flickr
40781340195_6294c45f8d_k.jpgUntitled by five1oh2010, on Flickr
41671026891_d0009f2430_k.jpgUntitled by five1oh2010, on Flickr
40961705874_f6d4ac8008_k.jpgUntitled by five1oh2010, on Flickr
That tail lamp set.....too bad about the kids college fund. :poke:
Wow, just effing wow. Don't take this wrong but your ass end looks awesome.
The CAR's ass end guys......jeez.
I used my Snap-On stamps but the numbers were just a little too big. I have been told the stamps you get from Harbor Freight are the correct size, though.
https://www.harborfreight.com/36-piece-18-in-steel-letternumber-stamping-set-63676.html
They offer 1/8", 1/4", and 3/8".
