Datsun 510 2 door sedan "SHAKOTN"
five1oh
If you are just checking this out I wanted to say there is a TON more pics on the previous page.  As per my M O I post like 6-7 posts at a time so if you are checking newest post and page you will likely miss something.  Not that you care but you might LOL.
I was FINALLY able to get pics of my cars together!!!!!!!:
But Before I do that Peter sent me some pics he took with his GOOGLE phone......HOLY CRAP!
28671551877_7536a12783_h.jpgUntitled by five1oh2010, on Flickr
28671550367_ec0661ad33_k.jpgUntitled by five1oh2010, on Flickr
41750740780_5c240e677d_k.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
  • Like 4
  • Replies 554
Pics with my Fairlady Z.............................. I LOVE my cars ???
41750742460_772c42da89_k.jpgUntitled by five1oh2010, on Flickr
29687556388_a244768e56_k.jpgUntitled by five1oh2010, on Flickr
28671564547_24bce5dc02_k.jpgUntitled by five1oh2010, on Flickr
43512073652_77d8dadf6b_k.jpgUntitled by five1oh2010, on Flickr
42841127714_ea2c825758_k.jpgUntitled by five1oh2010, on Flickr
28671551777_8ccf411f05_k.jpgUntitled by five1oh2010, on Flickr
29687504328_186bff96d7_k.jpgUntitled by five1oh2010, on Flickr
29687504068_d517dc27a8_k.jpgUntitled by five1oh2010, on Flickr
43558792631_e370f49e32_k.jpgUntitled by five1oh2010, on Flickr
29687502518_b3321bb764_k.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
  • Like 7
In the garage alone:
28671562657_5df20ae939_k.jpgUntitled by five1oh2010, on Flickr
43512072562_7788b61fc5_k.jpgUntitled by five1oh2010, on Flickr
43512072442_7f09d230e5_k.jpgUntitled by five1oh2010, on Flickr
42653670495_2f4a65e1bd_k.jpgUntitled by five1oh2010, on Flickr
First time ever sharing the garage together:
42841104164_8d091eaacc_k.jpgUntitled by five1oh2010, on Flickr
43512048442_91efbfd9a3_k.jpgUntitled by five1oh2010, on Flickr
43558786711_4c8c912cb1_k.jpgUntitled by five1oh2010, on Flickr
29687498168_5dfc276561_k.jpgUntitled by five1oh2010, on Flickr
43558785961_133b0479a0_k.jpgUntitled by five1oh2010, on Flickr
FUN FACT --- My two cars have identical spec wheels (15x8 zero offset) but the tire size is 10mm diff on track width (195-50-15 on 510, 205-50-15 on z).  When I can finally afford real Wat's I will go with 15x8 zero on the 510 and 15x8.5 on the Z
On Sunday I finally located the correct plug for the ignition control module but have yet to install it.  In other news I completed my HOOD SHOCK install and it went AWESOME.  I know people use different setups when it comes to these things but I wanted to do it exactly like my white car in years gone by.  I prefer a longer shock that makes it easy to install by drilling through to the inner fender and using nylon spacers along with screws and nylock nuts.
For those that like my setup I run the following:
2 - SG426001 Stabilus shocks (Honda Accord Wagon 94-97 Rear trunk lid support)
2 - 1/4" nylon spacer (for top that uses a 1/4" OD screw)
2 - 1/2" nylon spacer (for bottom that uses a 1/4" OD screw)
2 - 1/4" x 1" stainless steel screw
2 - 1/4" x 1 1/2" stainless steel screw
4 - flat washers
4 - 1/4" nylock nuts
29707171188_3dc9b0f2c3_k.jpgUntitled by five1oh2010, on Flickr
41769899990_b587279147_k.jpgUntitled by five1oh2010, on Flickr
41769900100_858ecc1ca7_k.jpgUntitled by five1oh2010, on Flickr
43531150022_0c4cb125ac_k.jpgUntitled by five1oh2010, on Flickr
42860334544_cc7ca3536f_k.jpg by five1oh2010, on Flickr
  • Like 4
Eric came over on Thursday and we finished the throttle cable, got the car running, and I finally DROVE IT!!!!!!!!!!!!!!!!!!!
As always it came with its own set of challenges.  What I thought would be the hardest part turned out to be the simplest.  First thing we did was get the throttle cable installed by cutting off the ends and modifying some linkages I had to accept a set screw.  Additionally we created a bracket for the carburetor side from a piece of scrap steel that Peter gave me.  Once the throttle cable was ran and mounted I installed the factory gas pedal and modified the carpet to fit:
41857906190_ec82bc6e01_k.jpgUntitled by five1oh2010, on Flickr
41857910230_facf8c97b1_k.jpgUntitled by five1oh2010, on Flickr
42949496224_967075c8ed_k.jpgUntitled by five1oh2010, on Flickr
43665920371_5a2bf488c7_k.jpgUntitled by five1oh2010, on Flickr
41857910210_85e377d94b_k.jpgUntitled by five1oh2010, on Flickr
41857903010_7175744058_k.jpgUntitled by five1oh2010, on Flickr
41857895780_3ee2d0f6c1_k.jpgUntitled by five1oh2010, on Flickr
43619595822_db5a2ec08d_k.jpgUntitled by five1oh2010, on Flickr
43665929231_cebe0eb3b0_k.jpgUntitled by five1oh2010, on Flickr
42949504084_3cbc571352_k.jpgUntitled by five1oh2010, on Flickr
29796065588_c17d8d5c48_k.jpgUntitled by five1oh2010, on Flickr
28777896347_5f79e668e8_k.jpgUntitled by five1oh2010, on Flickr
42949501514_acb33703f8_k.jpgUntitled by five1oh2010, on Flickr
43665928151_a01fc4e4c9_k.jpgUntitled by five1oh2010, on Flickr
After the throttle cable was done we turned our focus to installing the distributor, firing, and then timing the motor.  Unfortunately the re built distributor was put together 180 out, in addition it did not come with the lower bracket or middle plate.  The lower bracket I had would not allow the distributor to sit where it needed to get the timing right even with modifications to the middle plate.  After messing with different combinations for about an hour Eric asked if Peter was willing to loan us his from his 510 with L20b.  Peter went home and popped his off and came back.  We put it in and the car fired right up.  We spent some time getting the timing right and then ran it for about 15 minutes total and made sure the cam was broken in correctly.  Once that was done Ralph came over and brought some different lower brackets he had.
By 830pm Eric was able to install my distributor with one of Ralphs brackets and an extremely modified middle plate.  It will work for now but I am still planning on getting the right pieces so the distributor can be installed correctly.  First drive was AWESOME and we almost ran out of gas at the top of the hill.  Was able to coast back to my house and get enough gas put in to make it to the gas station.
All of these are videos if you click on the picture:
29796063718_bfb3d890d5_b.jpgUntitled by five1oh2010, on Flickr
28777909257_02c5970842_b.jpgUntitled by five1oh2010, on Flickr
FIRST DRIVING VIDEO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
28777936767_3245446092_b.jpgUntitled by five1oh2010, on Flickr
41857949880_bcd68cd954_b.jpgUntitled by five1oh2010, on Flickr
Gas Station Pics:
28777897357_c41ce89877_k.jpgUntitled by five1oh2010, on Flickr
28777898527_6e5a32cb2d_k.jpgUntitled by five1oh2010, on Flickr
42949486124_2ad0b8a9e7_k.jpgUntitled by five1oh2010, on Flickr
28777901187_4ece79b598_k.jpgUntitled by five1oh2010, on Flickr
42949494344_7d33cdc76d_k.jpgUntitled by five1oh2010, on Flickr
29796066308_ac737399f6_k.jpgUntitled by five1oh2010, on Flickr
42949495664_5984e4fe17_k.jpgUntitled by five1oh2010, on Flickr
41857909770_3759acc4cf_k.jpgUntitled by five1oh2010, on Flickr
43619595622_8fc1f7ec1f_k.jpgUntitled by five1oh2010, on Flickr
42949504654_50aef9a79c_k.jpgUntitled by five1oh2010, on Flickr
  • Like 3
It drove great and PULLS HARD but there were some minor issues I needed to address.  The rear tires were rubbing the inner fender and I noticed it was leaking a good amount of oil which appears to be coming out of the base of the oil dip stick tube.  The radiator held water and we got it pretty hot.  I still have no gauges, signals, or brake lights, and fuel runs out of the carb funnels after I shut it off but I must say it was SO MUCH FUN for the 10 minutes I drove it LOL
29796067968_62b3e05f43_k.jpgUntitled by five1oh2010, on Flickr
On Friday I forgot to bring my laptop to work (DARN IT!) so I attended two meetings in the AM and decided to go home for the day.  When I got home I pulled the Z out of the garage, arranged to have my fenders rolled a bit and scheduled a wheel alignment in Fairfield in the afternoon (30 min drive).  It was 90 degrees so I put together a roadside kit of tools, duct tipe, wire ties etc.  I also purchased a fire extinguisher and signed up for AAA for the first time (20 years of owning old cars, mostly datsuns with no coverage lol).
I set out and first stopped at the muffler shop to drop off the timing light I borrowed.  Then I headed 15 miles to my friend Pavel's house for some minor (I hoped) fender tweaking:
Before I left I finally installed my rear view mirror and adjusted my fender mirrors (since I have no brake lights...)
43643846242_a121bf1671_k.jpgUntitled by five1oh2010, on Flickr
43643848742_b83c343c86_k.jpgUntitled by five1oh2010, on Flickr
At Pavel's house:
42787690235_b223ea447d_k.jpgUntitled by five1oh2010, on Flickr
42974457874_0154d140c9_k.jpgUntitled by five1oh2010, on Flickr
43690735721_c7af86979f_k.jpgUntitled by five1oh2010, on Flickr
42974444224_bac782d2b7_k.jpgUntitled by five1oh2010, on Flickr
So the right rear was rubbing a bunch more when I hit bumps so we had to roll the inside where the patch plate was and grind down the spot welds.  The left side required grinding down just two spot welds and a very minor roll.  After rolling Pavel resealed the inside and painted it black.  He told me to go to the alignment shop and stop by on the way back to check if there was any more rubbing.  After leaving his house I immediately could tell it was much better and couldn't hear or feel ANY rubbing ?
As you can imagine I was quite nervous since the car was technically done and there was some minor risk of ruining Eric's bodywork..........the good news is the rolling was up inside the fender on the inner fender that was still separated from the body by about an inch.
I left Pavel's and it took me about 30 minutes to go 15 miles (I hit Friday traffic on I-80 at 2pm in 90 degree heat).  I got off the freeway and was stuck at stoplights.  Anyways by the time I got to the alignment shop the car was SUPER hot...when I shut it off it pissed some water and then a bunch of fuel was leaking out of the side of the carbs onto the header.  I got my towel out and tried to stuff the velocity stacks and had my fire extinguisher ready.  Thankful to say I had no issues and was very impressed that the radiator actually held water.
One thing I will be doing is adding an overflow tank so water can go out/in as needed.  Before I left the alignment shop the car was cooled down and I was happy that the radiator was still full.  I also think I will try to add a fan shroud since I am running the stock fan (for now).
What is crazy is once I got it on the rack and he dialed it in to the computer he told me it needed NO adjustments.  He didn't even touch it with a wrench!!!!!!!!!!  What he explained to me was that caster should be .5 degrees lower on the left and the toe should total 1/8" or .125.  CHECK OUT MY RESULTS BELOW!!!!!!!!!!!  Mine was .4 degrees lower on the left and .11 total TOE.  I seriously couldn't believe it as I didn't measure ANYTHING when setting it up.  I eyeballed that the wheel was centered on the fender with the TC rods and then pushed out the lower control arms to get enough camber to look even and clear the fenders.  The upper camber plates I had adjusted as far IN as I could without having to cut the top hat out.  And lastly I adjusted Troy's steering rods to get the wheels as straight as I could by eye.
One thing I noticed on the drive over is it felt AMAZING on the freeway so I thought it was close but had no clue nothing would need to be done.
42787677955_cac060bf99_k.jpgUntitled by five1oh2010, on Flickr
43643855862_6c5f2bcbdf_k.jpgUntitled by five1oh2010, on Flickr
42787677265_3c643454f1_k.jpgUntitled by five1oh2010, on Flickr
41882508830_736fcb43ca_k.jpgUntitled by five1oh2010, on Flickr
43690734851_02b2b5c7ed_k.jpgUntitled by five1oh2010, on Flickr
42787686345_5f24d61d63_k.jpgUntitled by five1oh2010, on Flickr
28801538837_0d6e7470e2_k.jpgUntitled by five1oh2010, on Flickr
28801539737_a361e2eb9d_k.jpgUntitled by five1oh2010, on Flickr
29820622798_809434aa25_k.jpgUntitled by five1oh2010, on Flickr
42787687575_37f6916f4a_k.jpgUntitled by five1oh2010, on Flickr
28801545707_74ec2e580d_k.jpgUntitled by five1oh2010, on Flickr
42787689985_b18a2c19ee_k.jpgUntitled by five1oh2010, on Flickr
29820624008_8557cb5a2f_k.jpgUntitled by five1oh2010, on Flickr
You will notice on the results above that my car is running 5.5 degrees of negative camber all around except the right rear at -5 degrees.  That would explain why my right rear has more clearance issues than the left.  Sadly I have NO adjustment on the rear (not even a slotted cross-member).  The slotted cross-member I had on Wanabre was damaged sadly if you recall.  Anyways I stopped back at Pavels on the way home and there was still some VERY MINOR rubbage on the right rear so he did one more pass with the fender roller and I believe it is good now.  On todays agenda I am going to try and tackle the oil leak at the dip stick tube.  I also noticed the right rear brake appears to be leaking and there is also a minor leak from the cut off speedometer cable on the transmission.  As I drive it more I am sure there will be some needs as I dial it in.
Overall I am THRILLED and can't wait to enjoy it more.  I plan on giving my kids a ride today.  That is all for now ?
So today I decided to start the day with my car in the air again uggghh. I figured out the engine oil leak culprit - a bad sending unit. The entire right side was drenched in oil from driving yesterday so I started with cleaning it all up. After that I started the car with it in the air I noticed a constant drip from the sending unit.  Called the local auto parts store and got a replacement an hour later. Installed it and fired it up again and NO more leak - YES!!!
the trans is still leaking with a very slow drip from the speedometer cable (it's just cut off out of the trans) so I need to order a new one of those. From what I hear the 510 automatic is the right length for a 280zx 5 speed - can someone please confirm???
the leak from the rear brake turned out to be oil from my left rear coilover - think I need a new set soon...
On on to the pics....
29832917618_04ed82cfb0_k.jpgUntitled by five1oh2010, on Flickr
43656259852_88ddb93c85_k.jpgUntitled by five1oh2010, on Flickr
29832917758_c2caee01e4_k.jpgUntitled by five1oh2010, on Flickr
43656260072_1e19c48b60_k.jpgUntitled by five1oh2010, on Flickr
After I put it back on the ground I wanted to measure ride height.......I'd call it about 2.5 inches.....need to cut the trans plate though to achieve that lol
41894570830_e3f8d67b86_k.jpgUntitled by five1oh2010, on Flickr
41894570400_18b7376d6f_k.jpgUntitled by five1oh2010, on Flickr
Also decided to install my Watanabe Falcon ?
29832917748_5ac5c1af29_k.jpgUntitled by five1oh2010, on Flickr
  • Like 4
1 hour ago, mrbigtanker said:
Nice job on the build. I got my Falcon i will install in my truck as well. To match the Watts I am putting on my truck. How much you want for the 510. lol
Keep asking........you will be met with silence lol
My very first car was a '69 2 door 510 and over the last 20 years I only lived without a 510 for 6 months (when I bought the hako) and it was the worst 6 months of my life.........lol
This car will likely never be for sale and if it is the ONLY way is if I'm happy in ANOTHER 510 that is IN my possession.
I appreciate your kind words.......it would definitely look AMAZING in your lineup with the wagon and 521.... like the ultimate 546 trifecta
Unfortunately for you it completes MY ultimate RHD trifecta: hako, z, 510
Edited by five1oh
On Saturday I was able to take my first pleasure drive by taking the car out to Berkeley cars and coffee.  It felt so good cruising down the freeway in the early morning.  I met my friend Naveed at the show and afterwards we went out to a local breakfast spot.
43008383234_aa3d83ce59_k.jpgUntitled by five1oh2010, on Flickr
43724436001_ecf7bcd8ea_k.jpgUntitled by five1oh2010, on Flickr
43676699162_7c83a84999_k.jpgUntitled by five1oh2010, on Flickr
42820542255_84cac90443_k.jpgUntitled by five1oh2010, on Flickr
43676732252_54403fe078_k.jpgUntitled by five1oh2010, on Flickr
29853820228_28cab72fe8_k.jpgUntitled by five1oh2010, on Flickr
43676690652_6e760667f6_k.jpgUntitled by five1oh2010, on Flickr
43724466121_ad4203ee2c_k.jpgUntitled by five1oh2010, on Flickr
41915542950_b44d04c0e9_k.jpgUntitled by five1oh2010, on Flickr
41915542470_9dfc0e1cfc_k.jpgUntitled by five1oh2010, on Flickr
Edited by five1oh
41915594890_05525891e0_k.jpgUntitled by five1oh2010, on Flickr
43008361254_6c130ecfcc_k.jpgUntitled by five1oh2010, on Flickr
29853757378_deef96f4d6_k.jpgUntitled by five1oh2010, on Flickr
After breakfast I had Naveed do a mini photo shoot of my car.  Here are my pics:
41915642550_232f174ead_k.jpgUntitled by five1oh2010, on Flickr
43676741992_00cf2c278f_k.jpgUntitled by five1oh2010, on Flickr
43724525061_fb51d80dbf_k.jpgUntitled by five1oh2010, on Flickr
43008389154_be987b616a_k.jpgUntitled by five1oh2010, on Flickr
43724499321_f5a9fb5edf_k.jpgUntitled by five1oh2010, on Flickr
43676710842_ac129cd439_k.jpgUntitled by five1oh2010, on Flickr
29853771018_079d57c654_k.jpgUntitled by five1oh2010, on Flickr
And now for Naveed's pics:
43008370234_fd7a3a44b1_k.jpgUntitled by five1oh2010, on Flickr
41915567420_47c5273e66_k.jpgUntitled by five1oh2010, on Flickr
29853793308_ff1ba5dae9_k.jpgUntitled by five1oh2010, on Flickr
41915586370_9de501f142_k.jpgUntitled by five1oh2010, on Flickr
43676701912_966c82fca1_k.jpgUntitled by five1oh2010, on Flickr
43008399694_c63ecf44c8_k.jpgUntitled by five1oh2010, on Flickr
43676738612_6a903e01e6_k.jpgUntitled by five1oh2010, on Flickr
42820548045_91352d8eee_k.jpgUntitled by five1oh2010, on Flickr
43676757652_7be51c4af8_k.jpgUntitled by five1oh2010, on Flickr
43724534391_76531e4f3e_k.jpgUntitled by five1oh2010, on Flickr
43676723762_7c93a96544_k.jpgUntitled by five1oh2010, on Flickr
43008368834_0541ea3e7f_k.jpgUntitled by five1oh2010, on Flickr
42820513185_56561d670c_k.jpgUntitled by five1oh2010, on Flickr
43724530971_007cd3c3f1_k.jpgUntitled by five1oh2010, on Flickr
29853770068_2f013d32ca_k.jpgUntitled by five1oh2010, on Flickr
43724543701_884f3e9f5e_k.jpgUntitled by five1oh2010, on Flickr
Drove the car to work today ?
43023686784_45e6cdc411_k.jpgUntitled by five1oh2010, on Flickr
43023677574_56c58def3d_k.jpgUntitled by five1oh2010, on Flickr
43023686764_08d2b889a0_k.jpgUntitled by five1oh2010, on Flickr
43740033501_6cf3a5617d_k.jpgUntitled by five1oh2010, on Flickr
43740033681_06f16d0f58_k.jpgUntitled by five1oh2010, on Flickr
43023686804_352bbea8c4_k.jpgUntitled by five1oh2010, on Flickr
43740033771_c3734baf1a_k.jpgUntitled by five1oh2010, on Flickr
  • Like 3
