Air fuel ratio gauge to achieve the correct fuel mixture at idle
  • Please log in to reply
22 replies to this topic
#21 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 70,348 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 10 December 2017 - 10:47 AM
Best mileage is 14.7 to 1 (theoretically) with down hills with light throttle higher than this. High performance... 13 or high 12s or whatever feels best but definitely lower numbers. The gauge won't tell you the best numbers to run, just the numbers you are running at.
Posted Image
#22 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,451 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '96 Pathfinder, too much other shite
Posted 10 December 2017 - 11:17 AM
Actually best mileage is to run lean. Many modern vehicles run in the 15s when cruising. According to the eco-modder guys, one step shy of meltdown is really where you want to be.
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#23 datzenmike
datzenmike
    KING RAT
  • 70,348 posts
Posted 10 December 2017 - 11:41 AM
Yes. Better slightly lean than slightly rich and not burning it all up. If lean, running higher compression helps and I think newer cars are now going up in compression. Direct injection can run into the 20s because the fuel is not mixed thoroughly over all the combustion chamber but only in a small cloud around/near the spark plug is at the correct ratio.
Posted Image
