ratrat Posted October 25, 2017 Report Share Posted October 25, 2017 I just picked up a63 L320 pickup. the fuel pump is leaking pretty good from the weep holes on the bottom, I'm guessing its a cracked Diaphragm from what i've read. Anyone got a heads up on if you can repair them, or where to track down a fuel pump or rebuild kit? Any other later models fit with this? Quote Link to comment
Stoffregen Motorsports Posted October 26, 2017 Report Share Posted October 26, 2017 This has been discussed in the 320 section a few times in the recent past. One potential source for parts, whether it be a replacement diaphragm or a whole new pump, is BMC. They used similar pumps in everything from MG's, Morris Minors, Austin Minis among others. Check Moss Motors website to compare pics and see for yourself. 1 Quote Link to comment
Draker Posted October 26, 2017 Report Share Posted October 26, 2017 From what I've seen ebay is or second hand will be your best bet for the pump. Diaphragms will be even tougher to find You might try posting a wanted ad in the classifieds and maybe one will turn up. Good luck. Quote Link to comment
datzenmike Posted October 26, 2017 Report Share Posted October 26, 2017 I don't know how purist your are but there are also electric pumps. Quote Link to comment
Stoffregen Motorsports Posted October 26, 2017 Report Share Posted October 26, 2017 I just googled "morris minor mechanical fuel pump" and came up with a few possible hits. https://www.google.com/search?q=morris+minor+mechanical+fuel+pump&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiJ2_3c2I7XAhVP3WMKHTQhAucQ_AUICygC&biw=1680&bih=910#imgrc=_ Somewhere there is a webpage (maybe it's here on Ratsun...?) that explains the interchangeability between early Datsun and BMC engines. I believe I read on that page that the BMC fuel pump is a direct fit. 1 Quote Link to comment
