hobbes_the_cat Posted November 21, 2017 Report Share Posted November 21, 2017 Dude! What's the color?! Quote Link to comment
]2eDeYe Posted November 22, 2017 Report Share Posted November 22, 2017 Nice tutorial :cool: 1 Quote Link to comment
the510keeper Posted November 22, 2017 Author Report Share Posted November 22, 2017 Trunk lid is in DTM hibuild primer surfacer Once you glue frame to skin changes exterior sheet metal and adds work, but you get less flexing. even though it is premature (like my ejaculation) Works out in the long run just more masking Bare naked surface rusted hood is next. Been stripped and sitting for years Instead of sanding the rust off decided to metal prep the rust off then sand Here is what it looks like after its bath with metal ech. I used metal prep socked 80 grit used paper to sand out the rust areas by hand And 30 mins DA 80gt sanding done and ready for body work 1 Quote Link to comment
the510keeper Posted November 22, 2017 Author Report Share Posted November 22, 2017 Here is the money shot, or more or less what she will look like. 8 Quote Link to comment
the510keeper Posted November 29, 2017 Author Report Share Posted November 29, 2017 Floor repair pics, just found them on my old phone. This phase went great and quickly Used Chris' repop floors with great success and ease Front right Left front Rear right Donor for all rear pans Rear left Under rear seat Rebuilt the hinges, found a great kit on facebook 5 Quote Link to comment
carterb Posted November 30, 2017 Report Share Posted November 30, 2017 Looking good James! Great to see all the metal work. --carter Quote Link to comment
the510keeper Posted January 19, 2018 Author Report Share Posted January 19, 2018 Back on this one, finally Roof Had some rust and the inner structure was bend and hanging down Cleaned the rust off with a purple wheel, been sitting for months after sanding with 80gt DA. Then realized I needed to glue that sub frame. I let that set up for 48 hours now minimal flexing in the skin Once cleaned pulled a few deep spots, however I will be floating the roof completely to make the next step quicker left her alone for a few days and wanted to take care of some rust Used a stud gun and welded pins to help move the patch where needed I chose to spot weld the lower area to keep heat down patched other areas that are questionable 2 Quote Link to comment
the510keeper Posted January 19, 2018 Author Report Share Posted January 19, 2018 Another week goes by and I realize at even 68 degrees in the shop surface rust came back, what a bitch. So I figured I would metal prep, sand then grind the metal before filler Metal prep kills rust but also does not allow bondo filler to stick. So kill rust sand off the coating it leaves and grind for filler. I used an 8inch sheetrock knife and made cake out of it Rock and Roll ready for primer 7 Quote Link to comment
the510keeper Posted January 29, 2018 Author Report Share Posted January 29, 2018 Quest for glory Roof primed and pulled all rear suspension Aligning panels before we do more fine filler work The left door was fucked but want to make sure the edges are cool, chipping fresh paint sucks A nice way to get them to line up Hammer, dolly, pulling oh my 4 Quote Link to comment
the510keeper Posted January 29, 2018 Author Report Share Posted January 29, 2018 Rotisserie time Rance seamsealed and Zero rusted the 1st coat no more worrying about flash rust, fucking hate flash rusting Let it dry 24 hours then applied a 2nd coat Rance is Datsunvilles blacksmith Cut these out to fit the 8inch wheels He made these panels to do a mini tub to the outer quarter 1 Quote Link to comment
the510keeper Posted January 29, 2018 Author Report Share Posted January 29, 2018 Next Just a few tiny pin holes then this underneath [/url] Also melted out the lead and started the carbon fiber kitty hair 1 Quote Link to comment
carterb Posted January 29, 2018 Report Share Posted January 29, 2018 Hard to believe this is the same car you started with. Doing great James! Save the Datsuns! 1 Quote Link to comment
Dolomite Posted January 31, 2018 Report Share Posted January 31, 2018 Looking good James. Quote Link to comment
Lockleaf Posted January 31, 2018 Report Share Posted January 31, 2018 Wow holy troll bomb. Hasn't been seen around here then BOOM! Quote Link to comment
WAGON JON Posted February 2, 2018 Report Share Posted February 2, 2018 MORE!!!! Quote Link to comment
the510keeper Posted February 13, 2018 Author Report Share Posted February 13, 2018 MORE!!!! That's what she said Blasted and sealed the rust out, then took a couple chucks of another rocker and fun begins Finally off the rotisserie While on the rotisserie i was able to seal one side of this coupe Melted the lead out seam sealed the whole bit 2 Quote Link to comment
the510keeper Posted February 14, 2018 Author Report Share Posted February 14, 2018 The last of the sheet metal got roughed also Should of used a better door Hood and door roughed fuck yeah 1 Quote Link to comment
Icehouse Posted February 14, 2018 Report Share Posted February 14, 2018 James got a question for you. So you've never had an issue with the seam sealer pealing off over time. We had issues in the engine bay where the inner fenders meet the firewall so we (me and frank) switched to using bondo (after expoxy of coarse) and haven't had any issues. We used the fancy seam sealer from Westco to, the kind you have to take a loan out to afford it. 1 Quote Link to comment
Dolomite Posted February 14, 2018 Report Share Posted February 14, 2018 Wow holy troll bomb. Hasn't been seen around here then BOOM! I was just fucking with James, there’s no bad blood between us. Hell, I was at his place for a party a couple weeks ago. You’d probably blush if you heard some of the shit we say to each other on a regular basis. 1 Quote Link to comment
Ranman72 Posted February 15, 2018 Report Share Posted February 15, 2018 I was just fucking with James, there’s no bad blood between us. Hell, I was at his place for a party a couple weeks ago. You’d probably blush if you heard some of the shit we do to each other on a regular basis. LOL we missed the party to damn busy to party right now 1 Quote Link to comment
the510keeper Posted February 22, 2018 Author Report Share Posted February 22, 2018 James got a question for you. So you've never had an issue with the seam sealer pealing off over time. We had issues in the engine bay where the inner fenders meet the firewall so we (me and frank) switched to using bondo (after expoxy of coarse) and haven't had any issues. We used the fancy seam sealer from Westco to, the kind you have to take a loan out to afford it. Ive been using SEM for years with no problems It's a 2 part, $25 a kit Usually drip it on the ground and when i scrap it up it takes concrete with it. And thats old dusty dirty concrete Quote Link to comment
the510keeper Posted April 27, 2020 Author Report Share Posted April 27, 2020 Back on Da Bird Just picked up the rebuilt SR20 NA S14, yes years in the making 4 Quote Link to comment
