Madmoos Posted October 16, 2017 Report Share Posted October 16, 2017 Hi does anyone have any info about fitting booster on a 520 pickup 1 Quote Link to comment
datzenmike Posted October 16, 2017 Report Share Posted October 16, 2017 I think wayno has done this. He'll be along.... 2 Quote Link to comment
wayno Posted October 17, 2017 Report Share Posted October 17, 2017 So, are you in Cape Town, South Africa? Is your truck right or left hand drive? 1 Quote Link to comment
Charlie69 Posted October 17, 2017 Report Share Posted October 17, 2017 I also did it but mine was easy as I am running auto trans. Quote Link to comment
wayno Posted October 17, 2017 Report Share Posted October 17, 2017 My 520 had a power brake booster in it from a 73/74 Datsun 620, and it barely fit with a stock carb, I had to use a Ford Courier brake master because the 620 brake master reservoirs would not clear the carb, when I changed over to dual SUs I had to make a change as the back carb was in the brake master, so I installed a 521 brake pedal assembly in the 520 and now it barely clears with thin pancake filters, when I figured this all out I put a power brake booster in my work truck, should have done it years ago. My 520 truck is LHD, I have no clue what a RHD 520 has for clearance, in my head I see lots of room. He also asked about disc brakes, but that depends on if he is going with ball joints or is keeping the kingpins. 2 Quote Link to comment
