Windshield wiper motor installation
720Girl
  • Replies 3
Did you pull them yourself? If dealing with a yard that doesn't allow you pull, plead to at least watch the Uninstaller because you just need to reverse the process. Do you have a manual? Follow that and if you get stuck come here, but most of the install is straitforward. Make sure to get the hardware (bolts) that come with it, because if your stuff is missing, the hardware is probably missing.
I'm not really sure what you are asking.
The wiper linkage just shoves on to the wiper motor and the motor screws in place on the passenger side of the firewall. You will likely need to remove the cowl over the wiper linkage in order to connect it to the motor.
The reservoir also goes on the passenger side.
If you need a play by play, download the factory service manual. Look at Datsun510.com/manuals.
