Chamse Posted October 8, 2017 Report Share Posted October 8, 2017 Hey everyone On my datsun 620 1976, the charge lights comes on, when i turn on the lights, and shut off when i turn the lights off... I am unsure if replacing it with a replacement 35a alternator will fix this, or i should try to upgrade it to a better one? or could it be some other problem? Kind regards Quote Link to comment
datzenmike Posted October 8, 2017 Report Share Posted October 8, 2017 Well you could try measuring the voltage across the terminals... 12.6 engine off over 14 when running Turn lights on should still be 14 may drop slightly. Check the plastic plug in the back is firmly seated and in place. Check the plastic plug for the voltage regulator is firmly connected. Battery posts and cables clean and tight. 1 Quote Link to comment
racerx Posted October 8, 2017 Report Share Posted October 8, 2017 Or take it out and bring it to AutoZone or prolly and get it checked. Quote Link to comment
datzenmike Posted October 8, 2017 Report Share Posted October 8, 2017 From Denmark? :lol: Quote Link to comment
racerx Posted October 9, 2017 Report Share Posted October 9, 2017 Mike, how do I know he's from Denmark? Quote Link to comment
datzenmike Posted October 9, 2017 Report Share Posted October 9, 2017 3 posts 0 warning points Location:Denmark Cars:Datsun 620 It's displayed under his avatar .... or it is for me. I assume everyone can see this? Yours says... 3,900 posts 0 warning points Location:NorCal Cars:71 Datsun 510 and 65 Mustang Fastback 1 Quote Link to comment
racerx Posted October 9, 2017 Report Share Posted October 9, 2017 I clicked his avatar I do not see what you see. Quote Link to comment
datzenmike Posted October 9, 2017 Report Share Posted October 9, 2017 I didn't know. I thought this was visible to all. Maybe the brushes are worn down too much. I've pulled brushes out of an old alternator and swapped them into another before. One of the three diodes may be bad or become un-soldered. The output would be much less. Quote Link to comment
Doctor510 Posted October 9, 2017 Report Share Posted October 9, 2017 I clicked his avatar I do not see what you see. It's UNDER his Avatar Quote Link to comment
Crashtd420 Posted October 10, 2017 Report Share Posted October 10, 2017 I clicked his avatar I do not see what you see. Are you on a phone or computer? If on the phone at the bottom of the page there is a full version button... press that and you find this extra info.. Quote Link to comment
racerx Posted October 10, 2017 Report Share Posted October 10, 2017 Thank u, yea im my phone. Now I see it. Quote Link to comment
