DatsWeird Posted October 5, 2017 Report Share Posted October 5, 2017 Can't figure this out: Other side lamp is flush, this one looks like hell Holes line up inside bucket, fender gaps are perfect. I see no adjustment, what gives? :frantics: Quote Link to comment
Crashtd420 Posted October 5, 2017 Report Share Posted October 5, 2017 How much of the lights if any did you disassemble? Just wondering if the bucket inside is upside down or something.... I found out on my 521 that the buckets need to go in a certain way to be correct.. That where I would look because as you said the fender gaps seem perfect.. 1 Quote Link to comment
datzenmike Posted October 5, 2017 Report Share Posted October 5, 2017 Re position the headlamp bucket. Quote Link to comment
DatsWeird Posted October 5, 2017 Author Report Share Posted October 5, 2017 Left the light/fender assembly alone when disassembled. Tried moving the bucket but adjustment is maxed rearward, butts up against fender. I can remove the two bolts on the radiator side and pull the panel containing the headlight forward but lamp angles up and holes don't align. I didn't notice if it was off before taking apart, only removed one fender to look for rust.. I'll snap some more pics and check orientation, maybe something is upside down Quote Link to comment
Crashtd420 Posted October 5, 2017 Report Share Posted October 5, 2017 Ya it's amazing what you figure out during reassembly.. . I almost learned the hard way about checking fender fitment before repainting..... Maybe the other side by comparison might shed some light on the problem.... Quote Link to comment
