njoz1200ute Posted October 3, 2017 Report Share Posted October 3, 2017 Someone cut the factory wire to my fuel tank. How do i find a replacement connector? Tried a spade terminal did not work. Quote Link to comment
datzenmike Posted October 3, 2017 Report Share Posted October 3, 2017 Should be close. You may need larger or modify it. 1 Quote Link to comment
Rjawm Posted October 3, 2017 Report Share Posted October 3, 2017 Or get these, the actual replacement connector... https://www.ebay.com/p/2989877-Packard-56-Female-Terminals-12-Gauge-Pack-of-25/2241249786?iid=162690092600&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D41375%26meid%3Da365bc651d9848558f3c4cc8b5a2743a%26pid%3D100005%26rk%3D1%26rkt%3D5%26sd%3D401310030180&_trksid=p2047675.c100005.m1851 Main draw back is you only need one but it's a bag of 25 lol. There are sellers with lower numbers of them but at a higher price that I found in my quick searching, look deeper you may find less at a more reasonable price. And if I remember correctly it's a GM alternator wiring boot that can be used to complete the updating of the wiring. 2 Quote Link to comment
captain720 Posted October 3, 2017 Report Share Posted October 3, 2017 Someone cut the factory wire to my fuel tank. How do i find a replacement connector? Tried a spade terminal did not work. Those spade terminals always need a jiggle to work :) not something you want on a fuel tank, I used some on my reverse lights and every time the lights don't work I just slam on the brakes and they come back on. :yawn: 1 Quote Link to comment
