Both turn signal lights & Dash lights on when key is on
craigba
Hey,
So I took my dash out to sort out some electrical issues, and when I put everything back, and turned the key to on, the turn signals both lit up and so did some of the dash lights. Any idea what may be going on? I'm thinking maybe a flasher might be bad?
In a Datsun 620. I checked all fuses and they are all good
  • Replies 8
Hey,
This is what caused the problem. What makes you think that a flasher decided to 'go bad' while you were doing this.
Go back and look at what electrical issues you sorted out.
