Fluvoldorf Posted September 21, 2017 Report Share Posted September 21, 2017 I'm going to slam my 84 720 and want to use the stock 14s it came with. What's the smallest size tires I can put on the stock rims? I have no idea when it comes to tires.i don't want it to rub when I turn. Quote Link to comment
datzenmike Posted September 21, 2017 Report Share Posted September 21, 2017 The most common tire for your '84 2wd is P195/75R14 on the stock rim and 7.7" wide and 25.5" diameter. You're going to buy a set of tires based on someone else's say so? Lower it and take a look yourself. In theory a 160/90R14 would narrow it to 6.30" wide and similar height so your speedometer is accurate. Quote Link to comment
Fluvoldorf Posted September 21, 2017 Author Report Share Posted September 21, 2017 Thank you for the info. To answer your question no I wasn't planning on ordering tires based solely on one person's input or say so. My father put all terrain tires on it but unfortunately has passed, now the vehicle is mine and I want to make changes I was unsure what tire size came on it stock and it is in California where as I am in Arizona and wanted to start getting things ready for when I moved it to where I live. I was hoping to not have to buy a stock set of tires to find out they were too big of an overall diameter for as low as I wanted to put the truck. I'm hoping to get it down to a 2-3 inch ride height. Quote Link to comment
