GoonLuv Posted September 19, 2017 Report Share Posted September 19, 2017 Hi Ratsun Anyone ever rewired their car with an American Autowire kit? I have purchased and installed the Power Plus 20 kit. I am down to the last few connections and I could use a little help. I am trying to wire the steering column and am just not sure what goes where. Below is the description of the wires in the kit that correspond to the steering column. Black Horn Relay Ground Horn button ground to the horn relay trigger Light Blue Left Front Turn Feeds the left front turn lamp bulb high filament and the left turn dash indicator lamp. Dark Blue Right Front Turn Feeds the right front turn lamp bulb high filament and the right turn dash indicator lamp Brown Turn Sw - Hazard 4 way hazard power feed wire from the Hazard flasher "L" terminal Purple Turn Switch Feed Turn signal power feed wire from the Turn Signal flasher "L" terminal. Yellow Left Rear Turn Feeds the left rear turn and brake lamp bulb high filament. Dark Green Right Rear Turn Feeds the right rear turn and brake lamp bulb high filament. White Brake Switch Power feed wire from the output side of the brake switch. Black Ground Connect to good chassis ground. Below is the wires in my steering column and what I believe they go to. Green Goes to Hazard harness Black Green Horn Black Red Headlight Relay Green Black Right Blinkers Green Red Left Blinkers Green Yellow ? Lt. Green Red ? Lt. Green Black ? I also have a Green Black wire with a Black collar on it that I'm not sure about. Thanks for any help you can provide. Adam Quote Link to comment
