Arp head studs
  • Please log in to reply
19 replies to this topic
#1 KamakSun
KamakSun
    Advanced Member
  • Members
  • PipPipPip
  • 101 posts
  • Cars:69 510, 99 E36 M3, 11 CTS V
Posted 10 September 2017 - 12:55 PM
Hi ratters,
I acquired a set of arp head studs that are for l24, l26 and l28 engines. Can these be use on an l20b?
Thank you,
Kamaksun
#2 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 72,286 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 10 September 2017 - 02:06 PM
10 of them, you can.
9 long and 1 short one left side center beside the carb.
Posted Image
#3 Doctor510
Doctor510
  • Senior Member
  • PipPipPipPip
  • 730 posts
  • Cars:Many 510's
Posted 10 September 2017 - 05:13 PM
Actually, 4 long and 6 short
#4 datzenmike
datzenmike
    KING RAT
  • 72,286 posts
Posted 10 September 2017 - 06:40 PM
Wow looking right at the picture and still got it wrong.  :blush:  :lol:  The FSM uses A and B. Thank-you Dr.
S..L
S..L
S..S
S..L
S..L
RAD
Posted Image
#5 KamakSun
KamakSun
    Advanced Member
  • Members
  • PipPipPip
  • 101 posts
Posted 10 September 2017 - 08:24 PM
And the set should have those?
#6 Crashtd420
Crashtd420
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,078 posts
  • Cars:1972 Datsun 521
Posted 10 September 2017 - 08:29 PM
There are alot of similarity between the L4 and L6. Just 2 extra cylinders, even the heads.... you should have what you need plus a few extra studs....
#7 distributorguy
distributorguy
  • Senior Member
  • PipPipPipPip
  • 1,209 posts
  • Cars:77 Datsun 620, 73 Datsun 620
Posted 11 September 2017 - 05:08 AM
You will need to install some of the nuts and washers as you set the head in place, if you mount the cam to the head prior to head installation.  Not a big deal - a little trickier than using stock bolts.  A LOT more time consuming.
#8 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,190 posts
  • Cars:http://www.4wdandsportutility.com/features/rover/0611_4wd_1957_range_rover/viewall.html
Posted 11 September 2017 - 08:12 AM
Have I mentioned that I hate head studs.
You don't NEED them on an L series. Even race motors don't need them. Late model head bolts are strong enough. And a lot less hassle.
#9 KamakSun
KamakSun
    Advanced Member
  • Members
  • PipPipPip
  • 101 posts
Posted 11 September 2017 - 08:20 AM
Ok, then that brings up a whole new topic. New thread time!!!!
#10 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,190 posts
Posted 11 September 2017 - 09:43 AM
It's not a new topic. Many have answered the questions you are asking.
#11 hang_510
hang_510
    too ol'skool
  • Senior Member
  • PipPipPipPipPip
  • 9,698 posts
  • Cars:71 2 door - LZ22 / 72 wagon - TBD
Posted 13 September 2017 - 09:30 PM
Its either the studs or the nismo HG, but this combo has yet to fail.
(never used nismo HG with stock bolts)
"I can spend time working on the Dattos, or wasting money at the strip club. You make the call." :D
I'll put on chain mail and a dirt bike tire jock strap and drive it!!!!!
#12 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,297 posts
Posted 13 September 2017 - 09:54 PM
I used the stock head bolts on my LZ23 and lost the Felpro head gasket within a couple months, I made another LZ head gasket and used an ARP head stud kit and have been driving it since without issues since 2011, I now have 3 engines with them as of a couple weeks ago.
If the Z24 engine had come with them stock, they would likely not be blowing head gaskets and have to have the head bolts re-torqued every year or two.
I like them myself, I just last week changed the head out in my 520 kingcab ute, I didn't have to chase the block threads, I just threaded the studs in with my fingers, dropped on the head gasket and the head, then put the washers/nuts on with torque lube, torqued them in 4 stages, put it back together and I was good to go.
#13 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,190 posts
Posted 14 September 2017 - 07:01 AM
I have built many, many high HP L series street and racing engines using stock head bolts and OEM Nissan head gaskets. Yes, most of the GT motors had o-ringed blocks, but not all of them.
I stand by my statement that you don't need head studs. The late head bolts with the ring around the top work just fine.
#14 scooter
scooter
    Member
  • Senior Member
  • PipPipPipPip
  • 791 posts
  • Cars:77 200sx, 2015 fz09
Posted 17 September 2017 - 09:13 PM
my lz23 is 12.3:1 and has a 100 shot on it and has not failed yet, arp head studs and that ugly composite z24 head gasket. this is year 3 on the motor and a couple bottles have been run though on the 100 shot now...
IMO its cheaper to push a head gasket out than break a rod so i will continue to use fail-pro shitty composite head gaskets even though i havint popped one yet... L series FTW
the last 2 years it was on a 75 shot and has had a dozen or so bottles ran through it
#15 Lozer
Lozer
  • Senior Member
  • PipPipPipPip
  • 473 posts
  • Cars:71 2door 510 Migumi. 15 Juke Nismo RS 03 shitbox tahoe, 03 moneypit 540i bmw.
Posted 23 September 2017 - 12:52 AM
I went through 2 sets of head bolts on my franken ka  (11.5:1) before i pulled the trigger on the studs, has held perfect ever since.  Will always use studs in the future after doing this shit 3 times.
"The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done"."
-George Carlin (1937-2008)
#16 datzenmike
datzenmike
    KING RAT
  • 72,286 posts
Posted 23 September 2017 - 06:48 AM
KAs use 'torque to yield' bolts that cannot be reused.
Posted Image
#17 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,190 posts
Posted 23 September 2017 - 08:30 AM
Hmmm.
Sure they can. It may be recommended that they not be re-used, but that's like a yellow light...merely a suggestion.
#18 datzenmike
datzenmike
    KING RAT
  • 72,286 posts
Posted 23 September 2017 - 10:01 AM
L and Z series head bolts are totally reusable.
 Let me put it this way, would you reuse torque to yield bolts that have already been stretched to their limit on one of your builds???
Posted Image
#19 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,190 posts
Posted 24 September 2017 - 07:40 AM
No, you're right, but back when I was building GT3 KA24 12 valve motors, we used them over and over again and I don't recall ever breaking them. To be fair, We didn't use the torque angle method to tighten them, we used a torque wrench set at 56#, just like a good L series bolt. Maybe that allowed them to be retain their strength.
Which brings us back to the original topic again - stock head bolts on racing engines.
#20 datzenmike
datzenmike
    KING RAT
  • 72,286 posts
Posted 24 September 2017 - 10:54 AM
What compromises the TTY bolts is that they are torqued to a certain mount then given n extra 90 degree? turn which stretches them like rubber. In theory they will return to original shape, no harm bone, but there is the real risk that they may over extend and be permanently stretched/distorted. L series are plenty strong and the Turbo zx ones even stronger. I think in over ten years here I have only heard of one L bolt breaking off in the block and can only assume it snapped off while loosening because it was seized..
Posted Image
