ecampvet Posted August 2, 2017 Report Share Posted August 2, 2017 Hello everyone, I have a 1995 p/u which leaks rainwater on the floor. I know my '84 has drains under the plenum but I cannot locate the drains for my '95. Any help/ advice would be greatly appreciated. Thank you! Quote Link to comment
datzenmike Posted August 3, 2017 Report Share Posted August 3, 2017 Run a garden hose into the plenum. Try one side at a time. Not full pressure just so it doesn't splash. You may notice water dribbling out from under the fender ahead of the door. Is there water leaking in on the driver's side? This would be a rusted out seam. If only on the passenger side this could be a seam but more likely the drain stopped up and water rising and dropping down the air inlet to the heater fan. (I'm assuming the fan is on the far right just like the 720s) If no leaking then probably the window seal is bad or rusted out at the window. 1 Quote Link to comment
