feralcat Posted July 28, 2017 Report Share Posted July 28, 2017 hey you guys anybody have this connector they want to sell? mine is all rusted out. i don't even know what it's called. it's the part that is being pointed to. thanks. 1 Quote Link to comment
flatcat19 Posted July 28, 2017 Report Share Posted July 28, 2017 Install an IR alt to get rid of regulator; splice wires together to complete circuit. 2 Quote Link to comment
banzai510(hainz) Posted July 28, 2017 Report Share Posted July 28, 2017 shoot some connector cleaner in there 1 Quote Link to comment
datzenmike Posted July 29, 2017 Report Share Posted July 29, 2017 That's not the voltage regulator connector. Looks like the auto choke heater relay. 2 Quote Link to comment
feralcat Posted July 29, 2017 Author Report Share Posted July 29, 2017 could you post a pic? i really appreciate your feedback. i don't know what an IR alternator is. thanks. Quote Link to comment
feralcat Posted July 29, 2017 Author Report Share Posted July 29, 2017 shoot some connector cleaner in there i tried that. it's really corroded and rusted 1 Quote Link to comment
feralcat Posted July 29, 2017 Author Report Share Posted July 29, 2017 That's not the voltage regulator connector. Looks like the auto choke heater relay.., that's what is corroded. and my charging light is comes on, but my alternator and regulator where just replaced. 1 Quote Link to comment
datzenmike Posted July 29, 2017 Report Share Posted July 29, 2017 Voltage regulator is at bottom left corner in this picture. The trouble with replacing everything is you likely as not add a bad part. So your alternator was bad but you replace it and the regulator but put in a bad regulator.. problem seems to not have been fixed. If you have the old parts try putting them back in. (never throw old parts away) For the heater relay just find or buy a 4? wire male/female plug and wire it in. Solder connections and use heat shrink tubing. 2 Quote Link to comment
feralcat Posted July 31, 2017 Author Report Share Posted July 31, 2017 oops. right. the voltage regulator has the same connector and the corroded piece is the one one that comes out of the wiring harness. i've searched for that piece with no luck. can you point me in the right direction. it's a 6 wire plug. thanks. 1 Quote Link to comment
datzenmike Posted July 31, 2017 Report Share Posted July 31, 2017 Any plug will work if it has 6 positions or more. Try a wrecking yard. It doesn't have to be exact it only has to work. 2 Quote Link to comment
feralcat Posted July 31, 2017 Author Report Share Posted July 31, 2017 will do.thanks KING RAT 1 Quote Link to comment
Charlie69 Posted August 2, 2017 Report Share Posted August 2, 2017 You can also go to the older style connector sold by Vintage Connections. http://vintageconnections.com/ MP6N Non-Latching Set $ 2.50 6-pin 6.3mm (1/4") spade-based non-latching M/F Connector Shell Pair, with 7 each 18-14 AWG, M63/F63 crimp terminals. White Nylon. Directly replaces original Hitachi non-latching housings from the 1960s-1980s. Also order these to properly crimp the wires. RTL Crimping Tool $35.00 Ergonomic Ratcheting Crimping Tool (with instruction sheet and standard open-barrel die set) 2 Quote Link to comment
feralcat Posted August 2, 2017 Author Report Share Posted August 2, 2017 You can also go to the older style connector sold by Vintage Connections. http://vintageconnections.com/ MP6N Non-Latching Set $ 2.50 6-pin 6.3mm (1/4") spade-based non-latching M/F Connector Shell Pair, with 7 each 18-14 AWG, M63/F63 crimp terminals. White Nylon. Directly replaces original Hitachi non-latching housings from the 1960s-1980s. Also order these to properly crimp the wires. RTL Crimping Tool $35.00 Ergonomic Ratcheting Crimping Tool (with instruction sheet and standard open-barrel die set) thank you!! Quote Link to comment
