The Geisha
  • Please log in to reply
83 replies to this topic
#81 f1ndM3aTaco
f1ndM3aTaco
    Advanced Member
  • Members
  • PipPipPip
  • 99 posts
  • Cars:1979 b310
Posted 15 November 2017 - 01:57 PM
I guess what I really wonder at this point is if I need any vacuum line running at all from the dizzy? right?
unless theres something on the carb that I'm missing and haven't run a line to?
Just cap off the small end of the brake inlet/outlet thing?
#82 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,339 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '96 Pathfinder, too much other shite
Posted 15 November 2017 - 07:17 PM
Vacuum line to dizzy is vacuum advance. You want that. Basically the only vacuum line you need to keep unless you have a brake booster, then you want that line too. Your Weber should have a small port for it. Google "Weber 32/36 ported vacuum" to find the port. The brake booster has a big line from it over to the intake manifold.
Yes you can remove that 3way valve it's called a thermo switching valve and switches vacuum based on water temperature. Its threaded into a water passage so removing it will lose coolant. Plug it with a pipe thread plug.
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#83 f1ndM3aTaco
f1ndM3aTaco
    Advanced Member
  • Members
  • PipPipPip
  • 99 posts
  • Cars:1979 b310
Posted 16 November 2017 - 11:16 AM
That's what I thought but you put it much more eloquently. Wasn't sure if there was something on the carb that I forgot about. Thanks
#84 f1ndM3aTaco
f1ndM3aTaco
    Advanced Member
  • Members
  • PipPipPip
  • 99 posts
  • Cars:1979 b310
Posted 16 November 2017 - 01:03 PM
My other question is on the fuel lines.
_-qKdjohDsxGRtw9T6zWvR31l4S2tdFlhOzDr1RQ
So from what I can figure the smaller red and black lines are part of the vapor line that went to the carbon canister which I no longer am using. Can I cap it at the end before going to the hard lines or should I remove the soft lines and cap the lines straight from where they come out of the tank (which means removing the check valve fastened to the panel behind the plastic)?
