Rear Axle alignment odd tire wear
  • Please log in to reply
29 replies to this topic
#1 Tom1200
Tom1200
    Advanced Member
  • Members
  • PipPipPip
  • 181 posts
  • Cars:Datsun 1200 coupe
Posted 26 July 2017 - 08:17 PM
So my  1200 race coupe has this bizarre wear pattern; inside edge of tires get scalloped out. Further inside edge is feathered as if the rubber is being pulled of to the inside. This could be a result of my somewhat driving style (read stop sling the car like a fiend) I don't think its a result of to much camber from something like bent axle tube (if it was i wouldn't expect the feathering)   Guesses welcome.  I think its possible the housing is moving around on the leaf spring centering pins.
 I suck at posting photos  it's here
http://datsun1200.co...id=26869&cid=18
#2 Ooph!
Ooph!
    Advanced Member
  • Members
  • PipPipPip
  • 185 posts
  • Cars:1973 620
Posted 26 July 2017 - 08:38 PM
Is the wear the same on both sides of the car ?
If that were an independent rear suspension I'd have to say bad bushings. This same wear occurred on my BMW streetcar it allowed the rear toe to change as the suspension traveled.
Bad spring or shackle bushings possibly ?
Nice lookin car too
#3 thisismatt
thisismatt
    Senior Damon
  • Senior Member
  • PipPipPipPipPip
  • 7,884 posts
  • Cars:'71 521, '69 521 donor
Posted 26 July 2017 - 08:39 PM
What tire pressure?
I'm your huckleberry.
One jump ahead of the lawmen
That's all, and that's no joke
These guys don't appreciate I'm broke
#4 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,445 posts
  • Cars:1971 2 door 510, 1969 4 door 510, 2002 Tacoma double cab
Posted 26 July 2017 - 08:59 PM
If the tube isn't bent, you won't have uneven wear on a solid axle. Gotta be driving style. If the axle is not aligned to the car.. you would change the thrust angle. The car would essentially just drive in a big circle if the fronts were dead straight.
Sounds like the car is defective and you should sell it. (To me)
View my 69 510 4dr Sedan - Build Thread
View my 72 1200 Sedan - Build Thread
View my 71 510 2dr Sedan - Coming soon.. ish
http://drakers.pl510.info
#5 Tom1200
Tom1200
    Advanced Member
  • Members
  • PipPipPip
  • 181 posts
Posted 26 July 2017 - 09:08 PM
Wear pattern occurs on both sides of car; it's more pronounced on the driver's side.
Tire pressure is 24 psi hot. They tires are Hoosier vintage TDs, they are bias ply tires.
This coming weekend I'll be doing checking various things; the car is mix and match and one of the things I suspect could be an issue is the aforementioned leaf spring pins. The hosting is a 510 wagon H190 on 1200 Nissan Motorsports spring pack. 1200s use a 1/2 pin vs 5/8ths on a 510. The bits came off a 1200 sedan project so I'm not sure if whoever put it together used the 1200 pin to locate the H190 housing, if they did there'd be enough play to allow the housing to pivot foreman aft. In another post I noted that the axles were not,spaced correctly so it wouldn't surprise me if it's the pins. Of course I don't know if that's causing the wear pattern.
#6 Tom1200
Tom1200
    Advanced Member
  • Members
  • PipPipPip
  • 181 posts
Posted 26 July 2017 - 09:22 PM
Draker it's not the car thats defective, see the video link below, red coupe just in front of the Spitfire camera car. This video is how I figured out that the axle might have a bit of end play, as in 2 mm each side, so decided to check how it was assembled (it appeared be to right but wasn't once a high side load was applied). If it's possible for a driver to be to comfortable with oversteer I'd say it's me.
https://m.youtube.co...h?v=7TsTgZJULSM
As for selling the car; you'll have to get past the wife; in 1984 I bought it from one friend and sold it to another the same day, then in 1989 got it back and turned it into a race car, then in 2000 sold it because I also had a single seat race car, got it back in 2003 and that's when the wife forbid me from selling it ever again.
#7 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,297 posts
Posted 26 July 2017 - 09:30 PM
Do you drive it like you just stole it?
#8 Tom1200
Tom1200
    Advanced Member
  • Members
  • PipPipPip
  • 181 posts
Posted 26 July 2017 - 09:53 PM
To quote a long time friend and professional driver coach "holy crap dude you drift that thing everywhere" so I think the answer is Yes. The consensus at the track days I instruct at is the same as well. Despite a good bit of single seater experience I'm a touring car driver at heart.
My fabricator, whose done some pretty high end work over the years was a bit taken aback by the wear; he's given me a list of things to check.
#9 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,605 posts
  • Cars:1966 520, 1967 520, 1985 720 ST King Cab, 1986 720 King Cab
Posted 26 July 2017 - 10:08 PM
I drive all my vehicles like I stole them!!!  LOL
#10 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,297 posts
So is 24psi enough pressure to keep the tires from rolling side to side?
#11 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,445 posts
Posted 26 July 2017 - 10:09 PM
In the first 20 seconds of the video you can see the problem. That ass end is sliding out non-stopped.
#12 wayno
wayno
    Datsunahaulic
  • Senior Member
  • 13,297 posts
Posted 26 July 2017 - 10:31 PM
I found myself holding my breath a few times watching that video.  :thumbup:
#13 KELMO
KELMO
  • Senior Member
  • PipPipPipPipPip
  • 2,170 posts
  • Cars:71 Goon, 72 1200 coupe x 2, 69 F250 72 510 4DR Sedan 2003 Maxima 2014 Frontier 2012 Xterra
Posted 27 July 2017 - 09:24 AM
1200's MUST be driven like they were stolen.....otherwise you get run over.  Well, unless said 1200 is Ron's then well, um.
NISMO: Nissan Impresses Sluts More Often
"Well, primer gray IS a color..." (quote: Kelmo's wife)
#14 datsunhead
datsunhead
    Hall Monitor
  • Members
  • PipPip
  • 50 posts
  • Cars:320,520,720,510, Y120, Frontier, Xterra...I'am sure I forgot some
Posted 27 July 2017 - 02:18 PM
Its called graining. The compound is dead. Buy new tires.
#15 Tom1200
Tom1200
    Advanced Member
  • Members
  • PipPipPip
  • 181 posts
Posted 27 July 2017 - 05:16 PM
@ Draker the video was shot before I took the excessive end play out the rear end, it no longer does those kind of tank slippers. Also passing guys half in the marbles doesn't help.
@ Wayno 24psi is normal, I've tried as low as 22 but that results in lower lap times
@ Kelmo, yes this is why I still race this car despite having a much faster single seater as well.
@ Datsunhead; after 30 years of racing I am familiar with training. The tires are indeed worn out, I buy a fresh set in the fall; I do two 3 day vintage race weekends followed by 3-4 local track days, so by the end of May they have something like 21-22 heat cycles on them. The issue isn't the graining but the scallop on the outside tread block; to me it's indicative of axle moving around or dampers gone south etc.
The Hoosiers will do about 12 heat cycles, they won't quite make 3 race weekends and so I don't have to worry about conserving the tires. There's no need to conserve them for track days as those don't matter.
#16 KELMO
KELMO
  • Senior Member
  • PipPipPipPipPip
  • 2,170 posts
Posted 28 July 2017 - 03:51 PM
Oh, and I'm not to bright.....Said Ron's Not Tom's :blush:
Here is picture of me feeling like a 1D10T.
#17 Tom1200
Tom1200
    Advanced Member
  • Members
  • PipPipPip
  • 181 posts
Posted 29 July 2017 - 11:52 AM
Kelmo you meant you to say Simon Kyne's (sp) coupe.........most 1200s are slow but his 200whp turbo A12 coupe scoots.
#18 docbainey
docbainey
    Advanced Member
  • Members
  • PipPipPip
  • 256 posts
  • Cars:75 610, RIP 68 510 4dr, 73 610 Hdtp, 71 510 goon, 72 510 4 dr
Posted 03 August 2017 - 02:12 PM
Jezuz, after watching that video, how many times have you backed this car into the Armco? Talk about lurid handling! wow!
on a side note you talk about the Datsun comp stuff, is that the T bar under the rear springs? or was that in the B210 Electromotive days?
#19 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 72,231 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 03 August 2017 - 04:22 PM
I'm no race car driver but what sliding are you all talking about???
Posted Image
#20 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,445 posts
Posted 03 August 2017 - 05:29 PM
Not much action in the first 20 seconds.. at all.  I guess I meant that more figuratively. Actually more like between 30 and 50 seconds in.  That red 1200 is all losing traction on corners.
