Need help identifying Datsun diff.
  • Replies 8
Or truck, or older Maxima wagon, or......something smaller like a B210
Count the splines on the axles.
Measure the opening on the housing.
PS, looks like it was dredged out of a river somewhere....rusted ring gear, & bearings.
Little value.
Sure looks like an H-190 differential. That's a 190mm diameter ring gear.
Truck will have 6 bolt studs for the wheels, cars are 4.
Truck 29 spline, cars are 23. Some early Datsuns were 13 spline.
Roadster, 510 wagon and 520/521 trucks were usually aluminum case, maybe early '73 620. Steel after that.
The gear ratio is stamped on the outer edge of the ring gear. Example 37:9 is 37/9 or 4.11
