KA24e, adding AC?
  • Please log in to reply
9 replies to this topic
#1 kixxvaz1
kixxvaz1
    Hall Monitor
  • Members
  • Pip
  • 27 posts
  • Cars:1974 Datsun 620, Yamaha FZ10, 1974 DJ5 Postal Jeep. 1983 GT Mustang Convert., 1930 Chevy Sedan
Posted 20 July 2017 - 04:06 PM
So after a few 100 plus degree days in the truck, (Gotta love CA near palm springs) I am wanting AC pretty bad.
I have the stock compressor that came with the KA24E and when I went to see if it was doable, looks like it will hit the steering box.
Looking for ideas to mount a compressor. Suggestions?
#2 FrankRizzo
FrankRizzo
  • Senior Member
  • PipPipPipPip
  • 336 posts
  • Cars:74 620/KA24DE & 2015 SRT392
Posted 20 July 2017 - 08:07 PM
Postal jeep???
There was a post here where someone had it done on a DE, of course that p0st would be worthless now thanks to photofuckit.
Im looking into it, on the DE you reportedly can move the A/C bracket up to the power steering hole and it will clear the steering box. I bought the DE compressor bracket for a 240SX on Ebay and I keep checking for a s13 compressor so I can test fit. I was going to use a vintage air underdash unit for the evaporator.
You (like me) have a '74 - so the condenser is a problem. The '75 and later trucks have a different radiator support that allows a larger 3 core radiator and also makes room for the condenser. A couple of the condensers that Vintage Air sells looks like they will work but will take some brackets. It is going to be a tight fit for radiator, condenser & fan in the front. I found brand new factory condensers online, but without the newer support they look like more work than bother, plus they are set up to run on R12.
thats about all I know so far.
Proper Capitalization is the difference between: I helped my Uncle jack off a horse and I helped my Uncle Jack off a horse.
#3 kixxvaz1
kixxvaz1
    Hall Monitor
  • Members
  • Pip
  • 27 posts
Posted 20 July 2017 - 08:40 PM
I'll try the power steering bracket. See if that is doable. I have one laying around somewhere. Also have the S13 compressor.
#4 FrankRizzo
FrankRizzo
  • Senior Member
  • PipPipPipPip
  • 336 posts
Posted 21 July 2017 - 04:57 AM
Sorry - if I recall, the dude moved the compressor bracket up to the power steering mounting holes in the block. That way the belts lined up with everything.
He did not use a power steering bracket.
#5 kixxvaz1
kixxvaz1
    Hall Monitor
  • Members
  • Pip
  • 27 posts
Posted 21 July 2017 - 07:36 AM
even better. I'll try that today
#6 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,237 posts
  • Cars:http://www.4wdandsportutility.com/features/rover/0611_4wd_1957_range_rover/viewall.html
Posted 21 July 2017 - 09:38 AM
Lots of talk about A/C lately.
Post some pics up as you go along. I'd love to see what you come up with.
#7 kixxvaz1
kixxvaz1
    Hall Monitor
  • Members
  • Pip
  • 27 posts
Posted 21 July 2017 - 08:12 PM
Didn't get a chance to try anything today but the PS pump area looks too tight for the large compressor at least on the E vs the DE. Maybe swap Alternator and Compressor possitions?
#8 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,823 posts
  • Cars:1966 520, 1967 520, 1985 720 ST King Cab, 1986 720 King Cab
Posted 22 July 2017 - 06:53 AM
This is one main reason I put a 1980 720 chassis under my 66 520, to get the steering box on the outside of the frame.
#9 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 4,237 posts
Posted 22 July 2017 - 08:23 AM
Yes, the 720 suspension and steering systems are a much better design as well.
Both the steering box and the idler arm are mounted on the outside, making room on both sides of the engine.
#10 kixxvaz1
kixxvaz1
    Hall Monitor
  • Members
  • Pip
  • 27 posts
Posted 12 August 2017 - 01:37 PM
Yeah, haven't done some tinkering, relocating the steering box would be the best route. On that note, I don't think I want to deal with that type of project right now and ma just suck it up till I find the time.
