Eriks Posted July 20, 2017 Report Share Posted July 20, 2017 Hi, does anybody know if the 610 tachometer works with an electronic ignition distributor? Thanks. Quote Link to comment
datzenmike Posted July 20, 2017 Report Share Posted July 20, 2017 I have the stock 710 tach and '79 Matchbox... works just fine... and it should. All points and EI do is open and close a path to ground for power to travel through the coil. It's basically an on/off switch. 1 Quote Link to comment
LenRobertson Posted July 20, 2017 Report Share Posted July 20, 2017 Pages Bookmarked from when I installed the factory tach in my '72 510 (with matchbox dist.): http://community.ratsun.net/topic/16328-how-to-wire-factory-tach-with-matchbox-distributor/ http://community.ratsun.net/topic/13454-620-tach-wiring/ http://community.ratsun.net/topic/69800-factory-tach-wiring/ http://elfecc.no-ip.info/510/Tachometer/Simplified_Tach_Hookup.htm These pages are for 510 or 620 but you can probably figure out if any of it applies to your 610 tach. Len 1 Quote Link to comment
