Which fitment best for 280z with zg flares?
  • Replies 2
  • 4 months later...
I think 16x9 zero offset would put the front edge of the wheel about even with the outer edge of the factory fender.
In the rear it is a few mm further out. By itself, it probably doesn't completely justify flares but its a good start. I'm actually considering this combination.
If you can get the -20mm wheels, those would probably be a better fit for what you're after. What wheels were you thinking of that had the negative offset?
