  • Replies 10
Aluminum jack from a g50 q45, with a porsche crank/handle.
Best combo ever/light weight.  In all my cars.
Rx7 and porches came with aluminum jacks, but are pricey.
The q45 ones are meant to lift a 4300lb car, and are cheap in comparison.  Albeit, hard to find.
Fix a flat is a very bad choice, most tire shops won't patch your tire after that, it's just better to swap for a spare or ya, call AAA.
I have been very fortunate about flat tires, most times when I have a flat, I need new tires, so I would use fix a flat then. If the tire is still in good shape I will call AAA
