El_Roy Posted July 22, 2017 Author Report Share Posted July 22, 2017 https://phoenix.craigslist.org/evl/pts/d/nissan-engine/6206799651.html I also came across this z24, he is asking $575 firm Quote Link to comment
datzenmike Posted July 22, 2017 Report Share Posted July 22, 2017 Too bad it isn't in a vehicle and running so you can see. An '84 engine would fit into your '81. Find out if it has the flywheel and clutch on it. In a pinch you could use your 22 flywheel. Keep in mind that your transmission has the release bearing collar for the Z22, 225mm clutch... it won't work properly on a 240mm clutch. You will need to swap your Z22 oil pan and pick up tube onto the Z24 for the front differential clearance. Other than this, mounts, rad, fuel line, throttle cable, exhaust, transmission, ignition wiring... all will bolt up. The Z24 has 130 ft lb of torque at 2,800. It will be an improvement over the Z22 on a heavy 4x4. Quote Link to comment
El_Roy Posted July 22, 2017 Author Report Share Posted July 22, 2017 Too bad it isn't in a vehicle and running so you can see. An '84 engine would fit into your '81. Find out if it has the flywheel and clutch on it. In a pinch you could use your 22 flywheel. Keep in mind that your transmission has the release bearing collar for the Z22, 225mm clutch... it won't work properly on a 240mm clutch. You will need to swap your Z22 oil pan and pick up tube onto the Z24 for the front differential clearance. Other than this, mounts, rad, fuel line, throttle cable, exhaust, transmission, ignition wiring... all will bolt up. The Z24 has 130 ft lb of torque at 2,800. It will be an improvement over the Z22 on a heavy 4x4. It comes with flywheel and everything except the clutch I belive.would i need to change my ecu as well? Quote Link to comment
datzenmike Posted July 22, 2017 Report Share Posted July 22, 2017 This post is so long I forget all the facts mentioned. You said it's an '81 but the engine looks like a Z24... Look between the two exhaust manifold pipes. Down onto the engine block just below the aluminum head. There is a flat space with the engine size stamped on it. Find out what engine you have in there FIRST.. 1 Quote Link to comment
Lockleaf Posted July 22, 2017 Report Share Posted July 22, 2017 Do exactly as Mike stated. But no, you won't need to change a computer. Quote Link to comment
El_Roy Posted July 22, 2017 Author Report Share Posted July 22, 2017 This post is so long I forget all the facts mentioned. You said it's an '81 but the engine looks like a Z24... Look between the two exhaust manifold pipes. Down onto the engine block just below the aluminum head. There is a flat space with the engine size stamped on it. Find out what engine you have in there FIRST.. Going to do so today 1 Quote Link to comment
Stoffregen Motorsports Posted July 22, 2017 Report Share Posted July 22, 2017 I'm looking at how close the two top bolts on the front cover are, and it doesn't look like a Z24 to me. I can't really see the bolts, but the height of the cover looks shorter than the tall Z24 cover. 1 Quote Link to comment
datzenmike Posted July 22, 2017 Report Share Posted July 22, 2017 Has Z24 valve cover, Z22 cover has longer bolts ... but these can be swapped. Just saying that if this already has a Z24 swapped in, it will be much easier. The fuel pump block off plate is there. Z22s had this but not the Z24 head. Z22 and Z24 heads are the same and... could also have been swapped. Bonus points. I see a fram oil filter! 2 Quote Link to comment
bottomwatcher Posted July 23, 2017 Report Share Posted July 23, 2017 I dropped a z24 in place of a z22 many years ago. It was a long block used JDM engine. Flywheel and intake bolted up, I used a header so I am not positive the exhuast manifold bolts up but ran that engine 20 plus years. Pulled it running fine for a ka swap. Got $28 at the scrappers after putting it on Craigslist for a week. Make an offer if he can't start it up, I don't think there is much of a market for that motor. 1 Quote Link to comment
Stoffregen Motorsports Posted July 23, 2017 Report Share Posted July 23, 2017 Right. Why swap to a Z24 when you can swap in a KA24? I understand a KA isn't "bolt in", but I'd go the extra mile and have a ton more hp. 1 Quote Link to comment
datzenmike Posted July 23, 2017 Report Share Posted July 23, 2017 Truck E or DE KA engine. Home made 1/2" aluminum adapter plate and Z24 carb and an L20B distributor and you don't even need to worry about needing a high pressure fuel pump, EFI wiring and sensors. 2 Quote Link to comment
bottomwatcher Posted July 24, 2017 Report Share Posted July 24, 2017 It's not that easy. A Z22 to z24 is a simple change one for the other. I forgot I had to swap oilpans but it all bolts up. No welding, pan modification, hose routing or engine mounts. Plus all the other Crap that doesn't reach or fit anymore with a ka swap. 2 Quote Link to comment
datzenmike Posted July 26, 2017 Report Share Posted July 26, 2017 Going to do so today So....... Z24 block? 1 Quote Link to comment
