Anyone got a 'how to install a weber 32/36?'
d.p
Hood closes and haven't checked the plugs yet.  Drove it around the block a couple times yesterday and it seemed to do just fine.  Cool to just cut the belt and remove the pump?
Will check the plugs today.
  • Replies 129
Got it installed and only problem I ran into was throttle cable was a little tight. Loosened it up and she purrs at idle. Throttle sticks though...can I use the stock return spring to bring it back?
In the first two photos I posted I tried to show the alignment of the throttle cable and bracket. I drilled a new hole and adjusted the angle of the bracket in the bench vise. That may help your application. Not much down time involved  :thumbup:
