Oil pressure gauge?
  • Please log in to reply
23 replies to this topic
#21 distributorguy
distributorguy
  • Senior Member
  • PipPipPipPip
  • 1,135 posts
  • Cars:77 Datsun 620, 73 Datsun 620
Posted 20 June 2017 - 04:07 AM
O'Reilly carries a copper oil line kit with the right fitting included for $20.  Made by AutoMeter if I recall.
#22 racerx
racerx
  • Senior Member
  • PipPipPipPipPip
  • 4,431 posts
  • Cars:71 Datsun 510 and 65 Mustang Fastback
Posted 20 June 2017 - 07:37 AM
Good to know cuz back on the day could not find it.
#23 Stoffregen Motorsports
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 3,901 posts
  • Cars:http://www.4wdandsportutility.com/features/rover/0611_4wd_1957_range_rover/viewall.html
Posted 20 June 2017 - 08:37 AM
Depending on the vehicle, I usually prefer a mechanical gauge over an electronic one. Mechanical gauges don't lie, while electronic gauges can. If you have poor grounds...
A few of you have mentioned that the plastic hose on a mechanical gauge is a danger. Yes, but you can easily run steel braided line in place of it. -3 AN is as big as you need. When going through the firewall, you can use a grommet to seal it and protect it, but I like to use bulkhead fittings. Not only does this rule out any potential abrasion failure, it also makes it so that if you want to remove the gauge cluster, you can simply disconnect the hose from the fitting on the firewall (not having to mess with the fitting on the back of the gauge, which may be hard to reach).
If multiple devices are desired ie- electrical gauge sender, spray bar, low oil pressure light, mechanical gauge, etc, I run a -3 AN hose to a junction block on the fender well, and then tee off from that. I have seen many engine block mounted tees break from the weight of too many things attached to it.
If you don't want to use an adapter fitting at the block (NPT to BSPT) then you can simply tap the hole in the block to 1/8" NPT. This can even be done with a heavy coating of grease on the tap, which will catch the shavings from the block. Ideally, you would tap the hole before the engine is assembled, but in a pinch, you can do it with grease.
#24 racerx
racerx
  • Senior Member
  • PipPipPipPipPip
  • 4,431 posts
Posted 20 June 2017 - 08:40 AM
Mechanical oil gauges will also tell you your oil pressure from idle thru driving, good to know. If its just an idiot light, it may be too late.
