86-720 Posted June 9, 2017 Report Share Posted June 9, 2017 a couple days ago my truck just sputtered just a couple of times and then the was fine. the next day it did it again but a little worse . then yesterday it did it really bad on the way to work I parked it for like 3 hrs and then went back out and started it and drove home with no issues at all . then this morning I was going to drive it to work and it died a couple of times and was sputtering bad so I took it back home and parked it . any ideas? thanks in advance Quote Link to comment
Lockleaf Posted June 9, 2017 Report Share Posted June 9, 2017 Start with a fuel filter Quote Link to comment
86-720 Posted June 9, 2017 Author Report Share Posted June 9, 2017 is the only fuel filter on the frame rail? I was thinking that or a fuel pump since it did it and then ran fine and then got worse. thanks Quote Link to comment
racerx Posted June 9, 2017 Report Share Posted June 9, 2017 also disconnect fuel line before carb and see if fuel is coming out when you press on gas, isolate issue, is it before the tank, after the tank or before carb or after carb...careful though fuel may go everywhere and helps when someone is there to help you. One starting car and one seeing if fuel comes out. Good Luck. Quote Link to comment
86-720 Posted June 11, 2017 Author Report Share Posted June 11, 2017 Is the fuel pump in the tank or external? Quote Link to comment
Crytek89 Posted June 12, 2017 Report Share Posted June 12, 2017 Is the fuel pump in the tank or external? External - both the filter and pump are frame mounted - passenger side just before the rear tire. Quote Link to comment
