GERMS Posted June 5, 2017 Report Share Posted June 5, 2017 1977 Datsun 620 King Cab Deluxe カラシ “KARASHI” First acquired April of 2009. Saw a listing on craigslist selling it for $1500 "running." After meeting with the owner at n offsite yard, he noticed the pickup was ransacked and several parts were missing. He sold it to be for $500. I was eventually able to scavenge for the missing parts and got the L20B running. Upgraded the carb years later to a 32/36 weber and drove it for several years as my daily. Crashed for the very first time in my life with it (hopefully the last), due to very dangerous spongy drum brakes and the car in front hard braking. A time after than, I blew the L20B on the freeway; oil every where. Needed it back on the road quick and so I was lucky to find a 1973 620 donor on craigslist with a L18 and swapped it over. Eventually, the L18 gave up and the 620 was parked for a couple years. I scored a good deal on a KA24DE, harness, and ecu, low miles, approximately 110,000 for $700. Also bought a 720 5 speed transmission from a ratsun member for $150. This is where my dreams and ambitions began; however, I was just a college student with a retail job selling cellphones. Graduated from college 2013; scored a decent job in 2015, and now we are here, dumping hard earned money on this project; and also into the necessary tools. The pickup's name is, "Karashi" a type of mustard in the Japanese cuisine. KA swap inspiration credited to ]2eDeYe thanks for the wealth of information! Tentative End Goal: (When it first came home) Years later of driving it with an L18, front end crash, Tiburon bucket seats Parts list: Updated: 06/05/2017 Engine/Transmission/Cooling Exedy Clutch and Flywheel Kit - RockAuto: $124.93 total ✔ ARP Flywheel Bolts - Ebay: ARP 102-2802 $41.49 ✔ Tranny Rear Seal - RockAuto: TIMKEN 710324 $3.34 ✔ 1996 240SX Header - Ebay: $86.99 ✔ Extra Header Exhaust Gasket - Ebay $7.86 ✔ Spark Plug Wires - RockAuto: DENSO 6714208 $45.74 ✔ Spark Plugs - RockAuto: NGK 7090 x4 $11.72 ✔ Cap and Rotor - RockAuto: AIRTEX/WELLS 3D1187 $20.89 ✔ Duralast Belt - Autozone: 350K3 35” 3 Ribs $12.38 ✔ AE86 Radiator - AE86 Shroud and Fans - Ebay $203.81 ✔ Datsun 720 Starter - RockAuto: USA INDUSTRIES 614250 $38.76 total ✔ 720 Clutch Slave Cylinder - RockAuto: EXEDY SC574 $10.52 total ✔ Accelerator Cable - RockAuto: PIONEER CA8937 $32.64 ✔ 240SX KA24DE EGR Block Off Delete Plate Blocker - Ebay: $7.96 ✔ Motor Mounts - RockAuto: DEA/MRC A2533 / A2532 Left and Right $19.43 ✔ Fuel Filter - RockAuto: PENTIUS PFB43178 x 2 $5.20 ✔ Fuel Pump - RockAuto: AIRTEX E2000 Electric Pump $56.79 ✔ Radiator - Ebay: AE86 Corolla 84-87 2-Row With Fan Shroud/Fans $203.81 ✔ Cold Air Intake - Ebay/Amazon: $126.25 ✔ Spectre 9499 3” 90 Degree Mandrel Intake Tube $31.53 Specture 87831 Black 3” - 2.75” Coupler $11.25 CXRacing 16mm Aluminum Vacuum Nipple $7.67 Kuramashop 14mm Aluminum Vacuum Nipple $8.99 Zspeedstarz 2.75” - 3” Transition Coupler + Clamps $7.58 Spectre 81413 Mass Air Flow Sensor Adapter $16.15 Spectre 8741 Black 3” Air Duct Hose $21.54 Spectre 8161 Black Small Cone Filter $21.54 Brakes/Wheels/Tires Front Rotors - 2002 Honda Passport, 2001-2004 Isuzu Rodeo, 2002-2003 Rodeo Sport 2X BENDIX PRT5402 { (rockauto w/ 5% off) $44.82 or Bendix $39.04 ✔ Calipers - 1988-1997 Nissan D21 Hardbody 4WD 2.4l Junkyard $27.14 ✔ Pads - CENTRIC 30003330 Premium Semi-Met Pads w/Shims Rock Auto $19.14 ✔ Hydraulic Hoses - Front Right DORMAN Part # H38568 and Front Left DORMAN Part # H38554 Rock Auto $21.98 ✔Rear Rotors - 1989-1993 Isuzu Amigo, 1988-1991 Isuzu Trooper, 1988-1995 Isuzu Pickup 2X DURA INTERNATIONAL BR31135 (rockauto w/ 5% off) $28.37 ✔ Calipers - Isuzu Trooper Junkyard $47.09 ✔ Pads - CENTRIC 30003980 Premium Semi-Met Pads w/Shims Rock Auto $16.78 ✔ Lines - BECK/ARNLEY 0731547 X 2 Rock Auto $18.55 ✔ Master Cylinder - 1979-1981 Datsun 280zx 15/16 A-1 CARDONE Part # 111837 {#46010P6500} Reman. w/o Reservoir Amazon Prime $55.32 ✔ CARDONE SELECT 131721 {#46010B5015} w/ Reservoir Rock Auto $38.79 ✔ Wilwood Proportioning Valve 260-8419 Amazon Prime $43.00 ✔ Goferit Inserts (To Flip Center Link) - $35.50 ✔ Suspension/Steering Centerlink - RockAuto: MEVOTECH MS30905 Supreme $45.79 ✔ --------------------------------------------------------------------------------------------------------- Engine (KA24DE from a 1996 Nissan 240sx) L18 is outta here! Cleaned up nicely with a pressure washer and some elbow grease ebay headers 4 Quote Link to comment
GERMS Posted June 5, 2017 Author Report Share Posted June 5, 2017 Radiator/Core Support Because the front radiator support was trashed, I removed the one from the 73 donor; the top is slightly different, but who cares, I was going to cut it up either way to fit a good radiator. Hence, the first step in this build was finding an aluminum radiator that fits with little modification. I know the efficiency of the radiator having a shroud and so the radiator MUST have one with electric fans. Found the perfect radiator for this and only needed minimal cutting of the core support. Radiator: 84-87 Toyota Corolla AE86 (Manual) Overall Size: 23"x18"x2" thickness with shroud and fans, 5.5" Test fitting the KA to figure out clearance and allowed me to work on fitting in the radiator Approximately 5" space from water pump pulley to core support wall Went to the junk yard and got a pair of these hold down brackets from an older model Toyota corolla, I grind them down to fit better with my dimensions Also grabbed a pair of these bottom mounts; will have to figure out how to attach them to the bottom frame; I already have an idea how Notice the shroud does not sit flush; manufacturer was lazy with grinding down the welds and making it fit right; will do that myself; that should give me half an inch more clearance with the distributor and water pump pulley and the shroud will be more efficient It's difficult to remove the radiator due to how close it is to the distributor; will have to cut the support, it blocks the bottom right corner of the radiator when trying to pull up Front bumper brackets should fit without a problem Shroud sitting in flush after an hour of tedious grinding of welds and cutting down the threaded tubes where the upper tabs sit; why does aluminum take forever to grind down! 1/2" clearance from the water pump pulley and 1" from the distributor connector; good enough! 3 Quote Link to comment
KoHeartsGPA Posted June 5, 2017 Report Share Posted June 5, 2017 Yay!, Another datto getting saved! What's your color code?, Looks same as mine.. 2 Quote Link to comment
Farmer Posted June 5, 2017 Report Share Posted June 5, 2017 You did your research for sure. Great build 4 Quote Link to comment
Draker Posted June 5, 2017 Report Share Posted June 5, 2017 Damn.. nice work! 3 Quote Link to comment
GERMS Posted June 5, 2017 Author Report Share Posted June 5, 2017 Yay!, Another datto getting saved! What's your color code?, Looks same as mine.. Unfortunately mine is missing the fender tag so I'm not sure, even after researching there isn't much out there. Closest I could find was code #931. 2 Quote Link to comment
GERMS Posted June 7, 2017 Author Report Share Posted June 7, 2017 In a tedious quest to find upper and lower radiator hoses. The engine side inner diameter of the hose has to be 1-3/8" (1.38") and of the radiator side 1-1/4" (1.25"). Oreilly's rep was super cool and ordered a bunch of molded hoses I though will work in some way or shape after modifying them and if I'm lucky I'll have both upper and lower tomorrow. One other option I thought about is using rubber inserts on the 1.25 radiator inlet/outlet and use one size flexible hoses then dress them up. Any other ideas? :confused: 2 Quote Link to comment
Fast720 Posted June 7, 2017 Report Share Posted June 7, 2017 Welcome Nice truck , you can make an adapter , or get an exhaust shop to make you one any size you need .a short piece of tube about three inches long , this also helps if you need to turn one end of the hose to fit better . 3 Quote Link to comment
Charlie69 Posted June 7, 2017 Report Share Posted June 7, 2017 Search "Radiator hose adadpters" and search "Radiator hose reducers". http://www.acehose.com/straight-reducer.html 2 Quote Link to comment
GERMS Posted June 12, 2017 Author Report Share Posted June 12, 2017 Datsun 720 5 Speed transmission cleanup. Not fun, but easier than expected. Still needs a little scraping and scrubbing in some corners. Got most of the crud by scraping it dry. I then sprayed it with Purple Power degreaser and scrubbed with the wire brush, I then scrubbed and then scrubbed some more, pressure washed to clean it up, then scrubbed some more. Approximately two hours worth. The harbor freight wire brush made the job simple. 240sx Manual Transmission Dust Plate 3 Quote Link to comment
GERMS Posted June 15, 2017 Author Report Share Posted June 15, 2017 I have an idea and I'm liking it...has anyone ever seen a 620 King Cab with the quarter windows deleted??? I've always thought the oval window makes the KC look a bit odd and they seem to be useless windows. What do you all think? 3 Quote Link to comment
Lockleaf Posted June 15, 2017 Report Share Posted June 15, 2017 Fast720 has a 720 single cab he extended, so it's like a windowless king cab. Looks fine, so i would think a 620 would to. If going to that much body effort, also consider adding some length to the bed side so it starts even with the bottom of the cab body, then tapers up to original height at the back of the bed. 3 Quote Link to comment
GERMS Posted June 15, 2017 Author Report Share Posted June 15, 2017 Very good observation and recommendation; without fixing that taper it does make the bed look out of place. Fast720 has a 720 single cab he extended, so it's like a windowless king cab. Looks fine, so i would think a 620 would to. If going to that much body effort, also consider adding some length to the bed side so it starts even with the bottom of the cab body, then tapers up to original height at the back of the bed. 1 Quote Link to comment
Lockleaf Posted June 15, 2017 Report Share Posted June 15, 2017 I'm a 720 guy myself and they have the same issue. I'm planning on correcting that on my project truck...eventually. :) 2 Quote Link to comment
GERMS Posted June 18, 2017 Author Report Share Posted June 18, 2017 BMW E30 projector headlights; low and high beams. The issue is the battery in the way of the low beam; but I have an idea that I hope will work. 2 Quote Link to comment
]2eDeYe Posted June 18, 2017 Report Share Posted June 18, 2017 Just my opinion, but with so many headlight options out there these days that don't require cutting, I just can't see using those. Your ride though and they do look cool :) Quote Link to comment
GERMS Posted June 18, 2017 Author Report Share Posted June 18, 2017 Just my opinion, but with so many headlight options out there these days that don't require cutting, I just can't see using those. Your ride though and they do look cool :) I'm a big fan of HID lighting and these will allow me to do that without blinding people. What other headlights do you recommend though? Quote Link to comment
willz Posted June 18, 2017 Report Share Posted June 18, 2017 I don't think I recall seeing a non-sealed beam light that fits Quote Link to comment
]2eDeYe Posted June 18, 2017 Report Share Posted June 18, 2017 I like my hellas :) Lot's of LED's that aren't too blinding, would be nice if the made some soft yellow ones. Quote Link to comment
hobospyder Posted June 18, 2017 Report Share Posted June 18, 2017 dapper lighting has headlights that fit and can get hid option as well as halos if you have the bank for them. i wish i could afford to buy another set 3 Quote Link to comment
GERMS Posted June 19, 2017 Author Report Share Posted June 19, 2017 This tool made it easy to shave off the plastic pieces.The high beam sits in loose with the retainer ring, that's because the OEM sealed beams have three little glass blocks that space the beam out enough for the retainer ring to compress it down and it also has three other glass blocks that prevents it from turning. For the next ones I cut, I will attempt and leave some plastic to work as the glass blocks do. Grrrr tedious work.7.25" length space for a battery. I was thinking of using a miata battery but then I found a beefier one at the junkyard that might work and took measurements. 7.25" x 6.5" Walmart part number, VP-26 or VP-26R. They sell for $50 new with a 1 year warranty. 540 CCA.I think I'm going to give it a try; I want HIDs and the miata battery might give me issues if I accidentally leave the lights on for a couple minutes. 2 Quote Link to comment
Dr ZED Posted June 19, 2017 Report Share Posted June 19, 2017 This tool made it easy to shave off the plastic pieces. The high beam sits in loose with the retainer ring, that's because the OEM sealed beams have three little glass blocks that space the beam out enough for the retainer ring to compress it down and it also has three other glass blocks that prevents it from turning. For the next ones I cut, I will attempt and leave some plastic to work as the glass blocks do. Grrrr tedious work. 7.25" length space for a battery. I was thinking of using a miata battery but then I found a beefier one at the junkyard that might work and took measurements. 7.25" x 6.5" Walmart part number, VP-26 or VP-26R. They sell for $50 new with a 1 year warranty. 540 CCA. I think I'm going to give it a try; I want HIDs and the miata battery might give me issues if I accidentally leave the lights on for a couple minutes. I like it. I like it a-lot There are small size batteries that are still very powerful but they cost a bit. Think $120-150 ea, but brand new. Not something you'll get if you're limited to wrecking yard prices. 2 Quote Link to comment
bens1088 Posted June 20, 2017 Report Share Posted June 20, 2017 FYI There is a sale going on and you don't have to get low AND high. You can get them separate, you just need to contact us. FATHERSDAY575 gets you 20% off the housings right now. :) 1 Quote Link to comment
GERMS Posted June 25, 2017 Author Report Share Posted June 25, 2017 Considering how difficult it is to find hoses that fit in 1-3/8" to 1-1/4" I instead got hoses that were 1-1/2" x 1-1/4" and used rubber inserts. I looked everywhere for rubber caps I could use as inserts with a 1-1/2" outer diameter 1-3/8" inner diameter and these were the only ones I could find. Quote Link to comment
